Motor Mount
Old Feb 20, 2009 | 07:44 AM
hawkturbo's Avatar
Default Motor Mount
ok i found the energy suspension motor mount insert some people use for turbo aplication whit good fedback but wanna now how good is this for my aplication wanna hit 450 WHP in mi integra dc2 is more fore track porpuse but wanna hit the street some times what you think abut this mount insert Thanks
Old Feb 20, 2009 | 08:12 AM
Terrible One's Avatar
Default Re: Motor Mount
get motor mounts. you said yourself it's for track purpose.
Old Feb 20, 2009 | 08:19 AM
EARLdaSQUIRREL's Avatar
official honda whore
they worked fine for me with close to 350whp, between the motor mount inserts and the tq mount inserts there was barely any motor movement and it was alot nice to drive than my current hasport mounts
Old Feb 20, 2009 | 08:54 AM
hawkturbo's Avatar
but no race like a pro LoL i live in dominican republic no got much money to spend but is nesesary i buy the hasport
Old Feb 20, 2009 | 06:07 PM
eg6b18boy's Avatar
get the avid torgue mounts cheap and very worth it.
Old Feb 20, 2009 | 10:00 PM
HiProfile's Avatar
Concerning inserts, the stock rubber helps damped a rather high amount of vibration, while low-frequency vibration (visible movement) is highly reduced by the insert because the soft stock rubber has nowhere to go. I have inserts in both my cars, and it does wonders. The EF has juse the 3 main mounts, 4th removed, and vibrates a bit. The EG has rear & torque mount inserts, and just as little motor movement. I've had good rubber and stock pizza cutters both spin smooth w/o wheel hop, althouh the car w/o poly suspension doesn't like rough roads as much.
If its a mostly track car, get solid poly mounts. It will vibrate like crazy, but you won't break anything (from motor movement, at least). My cars see the track as often as Alan Greenspan gets ***** (I think), which is why I didn't bother with solid poly mounts.
Old Feb 21, 2009 | 03:11 AM
hawkturbo's Avatar
thanks for the advice
SoullessJapaneseMachine
16
Dec 24, 2020 07:11 PM
thundernoodle
K Series
Feb 14, 2011 04:19 PM
t0kyoStatus
Mar 6, 2009 11:09 PM
civicsi18
Oct 27, 2008 12:05 PM
Si Speed
Oct 6, 2007 03:03 PM
