FPR Vacuum port
Old Feb 19, 2009 | 03:23 PM
SlowReaction's Avatar
Default FPR Vacuum port
I think this goes in here since its a FI car. I wanted to know if it would be fine to not run vacuum to the FPR. Would it be ok to use the port only for positive pressure and not vacuum?
The regulator on the car is 1:1 Fuelab regulator.
Thanks.
Old Feb 19, 2009 | 04:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: FPR Vacuum port
some people tune cars with no vac reference on the fp reg.
i dont see whats goin on why you dont want vacuum to the top. and a am assuming you are talking about putting the port to something between the turbo and throttle plate?
Old Feb 19, 2009 | 04:13 PM
Jas9848's Avatar
boosted cars need fuel pressure raised 1 psi fuel pressure/1 psi of boost. all motor cars run fine on a constant pressure.
Old Feb 19, 2009 | 04:51 PM
Scott_Tucker's Avatar
The reason there is a fuel pressure regulator with a vacuum port in the first place is to keep the pressure differential between the fuel rail and the intake manifold constant.
Old Feb 19, 2009 | 04:52 PM
You are correct. Its a kseries boosted car with FPR mounted on the firewall. Just trying to see if it would be fine with out vacuum and just boost pressure.
Old Feb 20, 2009 | 07:33 AM
Mr. Badwrench
you can do it, but you will have higher duty cycles. hook it to manifold vacuum. it is designed to fun that way. you dont need that much fuel when the engine is in vacuum.
Old Feb 20, 2009 | 01:35 PM
Yea I ended up just hooking it to the manifold. Thank.
Old Feb 21, 2009 | 03:52 AM
DaveF's Avatar
the idea of hooking it to vacum, would be to lower the pressure, where you dont need all the pressure, if you leave the pressure high in the vacum region, then you might run out of injector timing in the fuel map, where as if you let the FPR get a vacum/boost sig, it would allow for more tuning in the vacum section of the fuel map.
Old Feb 21, 2009 | 03:59 AM
Bailhatch's Avatar
yes
94 _EG_Swap
Feb 17, 2009 04:40 PM
8083tcman
Feb 14, 2009 06:12 PM
ziggz501
Mar 28, 2007 04:04 AM
