Motor Build
Old Dec 17, 2007 | 01:13 PM
bvilleteggy62's Avatar
Default Motor Build
I'm going to be building up a b18 and then boosting.. just wondering what type of pistons i should use to help me gain the most power? i'm also thinking about doing cams too and im not quite sure which kind will help me get the biggest gains.. thanks
Old Dec 17, 2007 | 01:48 PM
Blahblah718293's Avatar
Default Re: Motor Build (bvilleteggy62)
i dont know anything about aftermarket internals, but so when someone who does comes in here thinking about helping ill ask this for him:
what are you building for? autox? street? or just another 500 whp build for nothing but track?
(edit) what are your power goals?
Old Dec 17, 2007 | 02:25 PM
Schister66's Avatar
Man U FTW
<u>MOVED to Forced Induction...</u>
Are you running stock sleeves?? Without any kind of information, its really tough to give youa good answer....
Old Dec 17, 2007 | 02:31 PM
GraphiteAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bvilleteggy62 &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to be building up a b18 and then boosting.. just wondering what type of pistons i should use to help me gain the most power? i'm also thinking about doing cams too and im not quite sure which kind will help me get the biggest gains.. thanks</TD></TR></TABLE>
Look into a nice set of billet pistons, JE's have always done me well, so I can recommend those with a smile. How much power do you plan on making?
Old Dec 18, 2007 | 10:23 PM
Default Re: Motor Build (GraphiteAccord)
i really would like to make a drag car.. but i will also be daily driving it too... i guess i would be happy with about 300 whp..
Old Dec 19, 2007 | 06:11 AM
Schister66's Avatar
Man U FTW
You can easily achieve 300whp on a stock LS/VTEC if you want. What's your budget for this setup?
My suggestion:
-GSR head
-ITR cams
-adj cam gears
-ARP headstuds
simple turbo setup and you have 300whp all day long....if you have E85 available, you can make even more power
Old Dec 19, 2007 | 03:02 PM
Default Re: (Schister66)
i already have a ls motor so i just want to add on to that.. just want some suggestions on some decent pistons and cams
Old Dec 19, 2007 | 03:20 PM
Schister66's Avatar
Man U FTW
It depends what compression you want, but i would go w/ CP 9.8:1 (SC7016) and Eagle rods
Old Dec 19, 2007 | 03:31 PM
Sr420Det's Avatar
300 is a pretty modest goal.
brooklynEG
Apr 4, 2011 07:26 PM
boostedls92
Sep 20, 2010 07:05 PM
bvilleteggy62
Oct 18, 2007 01:24 PM
blkb18
Oct 9, 2006 04:02 PM
ek9tl
May 27, 2006 06:42 PM
