motec setup i made
Old Oct 7, 2003 | 07:36 PM
SEFIxCivic's Avatar
Default motec setup i made
Old Oct 7, 2003 | 08:00 PM
SEFIxCivic's Avatar
Default Re: motec setup i made (SEFI8LOxCivic)
Old Oct 7, 2003 | 08:02 PM
Turbocivic94's Avatar
That looks nice. Is that for u and how much did it cost.
Old Oct 7, 2003 | 08:39 PM
ludicrous's Avatar
Nice work
Old Oct 7, 2003 | 08:56 PM
bambooluv's Avatar
Default Re: motec setup i made (ludicrous)
damn nice work drew
Old Oct 7, 2003 | 09:05 PM
RenoRacing's Avatar
Default Re: motec setup i made (bambooluv)
beatiful wiring man! I'm jealous! Bet that shiz' is expensive, nice work for sure though!
Old Oct 7, 2003 | 09:17 PM
30psi Teg's Avatar
Default Re: motec setup i made (RenoRacing)
Nice setup man where did you get the plastic wire covering at? All I can find is that convoluted ****.
Old Oct 7, 2003 | 09:54 PM
TurboDANDEE's Avatar
Default Re: motec setup i made (30psi Teg)
bad-*** as always!
Old Oct 7, 2003 | 10:57 PM
DLB1994's Avatar
Default Re: motec setup i made (TurboDANDEE)
Old Oct 7, 2003 | 10:59 PM
boostaholic's Avatar
Default Re: motec setup i made (DLB1994)
Drew, is that just a peice of plexiglass you used to mount everything to? Looks good
Old Oct 7, 2003 | 11:26 PM
ninesecrx's Avatar
Default Re: motec setup i made (boostaholic)
Very nice setup
Old Oct 7, 2003 | 11:42 PM
Kack's Avatar
Default Re: motec setup i made (ninesecrx)
ditto, on how much...im thinking of getting motec.
Motec is a standalone right? And it works good with obII hondas?
Old Oct 7, 2003 | 11:44 PM
Full-Race Javier's Avatar
very nice the plexiglass makes it look real clean, maybe ill try that with my autronic
Old Oct 8, 2003 | 12:21 AM
hybrid93SIvic's Avatar
Default Re: motec setup i made (javierb14)
god damn that is sooo nice lookin'...agree with everyone else what was the cost/price??
Old Oct 8, 2003 | 12:23 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: motec setup i made (hybrid93SIvic)
Milspec?
Either way it looks killer!
Old Oct 8, 2003 | 01:56 AM
SEFIxCivic's Avatar
Default Re: motec setup i made (Arturbo)
thanks for the compliments everyone, it took a long time to build.
yes, everything is mounted on plexiglass. about the wire harness itself, it is partially raychem (milspec), partially standard heat shrink, and the connectors are milspec contacts in a plastic case.
this actually started as a prototype. The real harness that i wanted to make was going to be full raychem heatshrink, but while building this harness i discovered a couple things that i didn't like about raychem.
first, a little background info. i was given a formula atlantic engine harness w/ full raychem heatshrink & boots to examine, and when i took it home i found out why I had gotten it for free. apparently, the harness had been rubbing on something and wore thru the raychem heatshrink to the point where a couple wires actually went past the insulation.
at this point, i decided to cut it open to see what i could learn, and found that the raychem heatshrink was really soft, which explains the frayed wires. in comparison, standard heatshrink has a harder texture, and is significantly more difficult to cut and i make the educated guess that it would survive better against abrasion. heat/fire wise, I would assume that the raychem is superior.
one thing i commend raychem for though is their boots/splitters. they are extremely difficult to cut thru, and appear very abrasion resistant.
in the immediate future, i plan on making a full raychem wire harness for experience, but at this point i'm not totally impressed, and i'm not sure if it justifies the cost.
95% of the cost of this project was spent on the motec system itself, to build the harness didn't take too much money, just a lot of my time.
Old Oct 8, 2003 | 02:15 AM
rjardy's Avatar
Very nice
Rob
Old Oct 8, 2003 | 03:11 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Thats really nice man, Good wiring job. I love clean wiring.
Old Oct 8, 2003 | 03:45 AM
Lei Siew Long's Avatar
nicely done.
Old Oct 8, 2003 | 05:20 AM
Tinker219's Avatar
Default Re: motec setup i made (Hatch4urSnatch)
Looks good SEFI, might have to think on this for my SpeedPro install(my gf has claim to the plexi-glass, maybe ill go ricer-ific and use one of those CF RacePlates)
Old Oct 8, 2003 | 05:24 AM
MiraiZ's Avatar
Default Re: motec setup i made (Tinker219)
The Michael Jordan of all stand alones...damn!
Old Oct 8, 2003 | 05:38 AM
done's Avatar
wow that looks good, glad to see your almost done
Old Oct 8, 2003 | 06:02 AM
ekb18c's Avatar
looks nice, how come you didnt put boots on all the connectors? I see a boot on a few of the connectors but not all. Other then that, it looks good.
Old Oct 8, 2003 | 12:03 PM
SEFIxCivic's Avatar
Default Re: motec setup i made (ekb18c)
not all of them have plugs because this started out as my prototype. i suppose i should have sat down and figured out what connectors and plugs i needed, but since I wasn't sure exactly how the harness would end up looking, i just kept it simple by ordering a bunch of 4 pin and 12 pin non booted connectors.
it's not exactly what i want just yet, there's a couple things i still want to try, but i need to finish other parts of my car, and this will do for now to get the car running.
i would say though that the $1250 motec charges to build a milspec harness isn't really that bad, after building this comparatively half-***, but equally time consuming harness myself.
Old Oct 8, 2003 | 12:18 PM
integra-modder's Avatar
Thats a lot of relays ya got there....
what are they all used for?
