most important gauges...
Old Sep 29, 2002 | 12:18 AM
Patron's Avatar
Default most important gauges...
will i need a boost gauge if i have an electronic boost controller eg. greddy profec a? also, what three gauges would be the most vital into maintaining a turbo setup?
1) boost 2) oil pressure 3) exhaust gas temp... i've been told a/f gauges are just pretty to look at. which do you think are the 3 i "need." thanks
Old Sep 29, 2002 | 12:26 AM
mitsuman's Avatar
Default Re: most important gauges... (ptran13)
3 needs..
1)boost
2)egt
3)a/f
Old Sep 29, 2002 | 08:05 AM
AVATAR's Avatar
I cant stand looking at my A/F guage bouncing all around all the time and it doesnt look right next to the pretty boost gauge Plus isnt it only accurate at WOT and sometimes on stoich? !
Old Sep 29, 2002 | 08:50 AM
fire7882's Avatar
Default Re: most important gauges... (AVATAR)
noob question
why do you need to know the exhaust temp?
Old Sep 29, 2002 | 09:03 AM
Quick 200k Mile Motor's Avatar
1) boost
2) a/f from wideband
3) nothing else
Old Sep 29, 2002 | 10:01 AM
speedymon's Avatar
Default Re: most important gauges... (fire7882)
If you are leaning out in boost your exhaust gases will be hotter.
Old Sep 29, 2002 | 12:11 PM
Patron's Avatar
anyone else have an opinion on the matter?
Old Sep 29, 2002 | 12:14 PM
jinxproof99's Avatar
New User
a/f gauges are pretty much crap.
Old Sep 29, 2002 | 12:40 PM
PrecisionH23a's Avatar
Default Re: most important gauges... (jinxproof99)
unless you get a wideband, which you have to change out every 1000 miles. go with the greddy egt gauge, its some good stuff
Old Sep 29, 2002 | 01:14 PM
yellowsub's Avatar
Default Re: most important gauges... (GudeH23a)
Why do you have to change it so often?
Old Sep 29, 2002 | 01:44 PM
TurbothisLS's Avatar
Default Re: most important gauges... (yellowsub)
i have egt a/f and boost
Old Sep 29, 2002 | 03:17 PM
blufke's Avatar
Default Re: most important gauges... (TurbothisLS)
i was gonna go with:
boost
egt
oil pressure
and anything else?
[Modified by blufke, 12:19 AM 9/30/2002]
Old Sep 29, 2002 | 03:23 PM
tony1's Avatar
Default Re: most important gauges... (blufke)
Motec PLM (professional lambda meter)...the best gauge you can have!!
Old Oct 11, 2002 | 01:45 AM
blufke's Avatar
why is that. the DIY kits run off the vx o2 sensor which lasts a lot longer than 1k.
Old Oct 11, 2002 | 02:03 AM
The sweed's Avatar
i would skip air fuel meter and get oilpressure, elektronic fuelpressure, boost, EGT and something that monitors knock. Than you home free.
Maybe an oiltemp too
[Modified by The sweed, 3:04 AM 10/11/2002]
Old Oct 11, 2002 | 02:33 AM
hondaswaper's Avatar
Default Re: most important gauges... (tony1)
Or the lambda Option on your Motec
Old Oct 11, 2002 | 02:35 AM
blufke's Avatar
Default Re: most important gauges... (hondaswaper)
anyone know anything about the autometer auto gage line? they are about 1/2 the cost of the ultra lites.
Old Oct 11, 2002 | 03:39 AM
SoulSurfer's Avatar
You get what you pay for.
Old Oct 11, 2002 | 04:12 AM
DsMWookie's Avatar
need to know exhaust temp so you don't melt your afterburner exhaust from AZ
JEes forkin noob
Old Oct 11, 2002 | 06:04 AM
POLLO's Avatar
Default Re: most important gauges... (forward_motion_crx)
1 boost
2 egt
If vehicle is tuned properly at the dyno no need for a/f gauge. Keep it simple !
Old Oct 11, 2002 | 06:59 AM
FredoSP's Avatar
Theres a post in the room .. Greddy 52mm and/or 60mm EGT and Boost at a good price, you should look in to them. Im considering this buy also.
Old Oct 11, 2002 | 08:28 AM
mos's Avatar
mos
Default Re: most important gauges... (FredoSP)
Boost/vac
EGT
oil pressure
Old Oct 11, 2002 | 10:03 AM
Speedworks801's Avatar
Default Re: most important gauges... (mos)
Do the FJO, it responds faster than the Motec PLM anyway, I've used both and definitely prefer the FJO Wideband. Pick up the datalogging software and the display and you will never regret it!
Old Oct 11, 2002 | 10:22 AM
TurboedGSR's Avatar
Default Re: most important gauges... (Speedworks801)
i think a narrowband a/f gauge is ok for the amount paid, until i have more money for a wideband. You CANT tune with it but at least it lets you know to let off the pedal youre running lean, eg. if fuel pressure drops.
EGT gauges are not that great and i wouldnt consider them a tuning device either, there are many variables that affect it, for example advanced timing makes the temps lower, so you might think youre ok when in reality you are leaning out. retarding timing will make temps higher so you'd think you need more fuel and really just run really rich. cam profile, cam timing also affects the temps
Old Oct 11, 2002 | 10:35 AM
TheIntegraGuy's Avatar
Default Re: most important gauges... (TurboedGSR)
I only have boost
I need a/f or exhaust temp.
