More Torque?
Old Dec 2, 2011 | 12:33 PM
bluemanic15601's Avatar
Default More Torque?
In a motor build I see a lot of difference in torque with similar hp ratings .... For example people running right around 400hp.... I've seen some with around 200ft/lb and some with over 300ft/lb .... How do you get the higher tq ratings on your build?
Old Dec 2, 2011 | 12:52 PM
Tony the Tiger's Avatar
Default Re: More Torque?
Faster spooling turbo, lower RPM when peak HP is reached, more stroke (LS/B20/GSR stroke differences). These things will affect the peak torque numbers.
Old Dec 2, 2011 | 01:12 PM
TheShodan's Avatar
Moderator
Absolutely. This is why it is key to pick the correct turbocharger to gain torque in addition to proper displacement. If you change displacement, don't just do Bore alone. Bore and stroke are what make the biggest differences.
Old Dec 2, 2011 | 01:16 PM
LightningTeg's Avatar
Community Builder
My stock LS setup made close to 300 ft-lbs because the turbo was at 20psi before 4000rpm
Old Dec 2, 2011 | 01:18 PM
TheShodan's Avatar
Moderator
*yuck yuck yuck*... I love it..
acuracer5
Jan 22, 2010 04:35 PM
Bitchin_Teg
Oct 8, 2005 08:23 PM
_Endless_
Mar 29, 2003 04:38 AM
TruePlayaz114
Jun 6, 2002 01:57 AM
degradated
Dec 26, 2001 11:34 PM
