More Boost?
Old Apr 23, 2004 | 06:21 AM
Atlas's Avatar
Default More Boost?
What things would I need to do to my internals to increase my boost with a TD-04H GReddy kit on a D16Z6? I was hoping somewhere around 12 pounds.
I was thinking new connecting rods, new piston rings, and new injectors. Would this be helpful?
Thanx in advance.
Old Apr 23, 2004 | 06:27 AM
TravSi's Avatar
Default Re: More Boost? (Atlas)
to run 12 lbs u would need injectors, pump, and 3 bar map...you can run that on stock internals...its recommended to beef up the internals of the motor to be safe but its not totally necessary, its a risk...motors are limited to power, not boost
Old Apr 23, 2004 | 08:59 AM
Machine1's Avatar
Get a thicker metal headgasket to lower your compression ratio also, and while you're doing that you might as well get head studs. The stock bottom end will handle 12 psi, if it's "tuned" right.
hondacura22
Apr 9, 2009 08:30 AM
deemack79
Feb 14, 2005 05:33 PM
crxturboh22
Jan 12, 2004 01:55 AM
speed
Nov 23, 2002 05:18 PM
X2BOARD
Apr 18, 2002 10:51 AM
