Modding Uberdata 1.66 to control IACV?
Old Apr 18, 2006 | 04:01 PM
O16581724 5 2 5's Avatar
Default Modding Uberdata 1.66 to control IACV?
As the title says, my car won't run on 1.7, i don't know why, but i have it running fine on 1.6 aside from the pulsing idle.
I posted on the Uberdata site, but i don't think anyone even goes there anymore.
Old Apr 18, 2006 | 04:33 PM
non-VTEC's Avatar
Default Re: Modding Uberdata 1.66 to control IACV? (O16581724 5 2 5)
version 1.70 has IACV control.......i dont know if it actually works but its there........
Old Apr 18, 2006 | 04:35 PM
Default Re: Modding Uberdata 1.66 to control IACV? (non-VTEC)
I know, and like i said, my car won't run on 1.7.
Old Apr 18, 2006 | 04:37 PM
non-VTEC's Avatar
why not? what does it do?
i had no trouble with any version from 1.2 up to 1.9.....
Old Apr 18, 2006 | 04:40 PM
It fires and instantly dies.
Old Apr 18, 2006 | 04:43 PM
non-VTEC's Avatar
thats odd.......there must be some setting your missing. maybe cold crank enrichment or something like that.
anyway you can maybe add the IACV control from version 1.70 to 1.66 but im not sure if it will work.
you need to post/ask on pgmfi.org and hope someone still visits the uberdata forum to help you.
Old Apr 18, 2006 | 05:06 PM
I tried that, it didn't transfer over right, but i don't know what i'm doing with programming. I used to get a CEL with 1.7, that went away, but it still doesn't run...
Old Apr 18, 2006 | 05:57 PM
Soccerking3000's Avatar
there is a place called pgmfi.org for this lol
Old Apr 18, 2006 | 07:49 PM
HiProfile's Avatar
Default Re: Modding Uberdata 1.66 to control IACV? (Soccerking3000)
I'd suggest trying to copy the idle section from a base 1.70 map and use that on your imported 1.66 map. Sometimes with uber, you have to start from the begining and work ahead one step at a time. Anoying, yes, but its not like you paid for stability
Theres a bunch of settings in 1.70 (don't use 1.7, aka 1.7beta) that can really mess things up if you set them wrong. A base 1.70 gsr map (imported/altered to whatever ecu you need) should always start a car, with the worst-case being a rich 10:1 or lean 17:1 idle. It will start with both, but lean wont like it at all. 16:1 usually idles fine.
theblkrascal
Honda Civic (2001 - 2005)
May 28, 2008 12:40 PM
iBrandon
Apr 21, 2007 11:40 AM
Gs-RAW
May 13, 2003 08:03 PM
SpoonfedDC2
Jan 29, 2003 05:28 PM
B18C-RnVA
Jan 19, 2002 04:05 PM
