Mitsubishi resistor box?
Old Mar 27, 2003 | 03:19 PM
TurboJesse
Guest
Posts: n/a
Default Mitsubishi resistor box?
Im wondering if a resistor box from a mitsu would work, im installing DSM 450's in my obd1 honda, it has 4 black wires and 1 white...thanks
Old Mar 27, 2003 | 04:30 PM
baphomet's Avatar
Default Re: Mitsubishi resistor box? (Mpir3)
test the resistance with a multimeter if its between 6.1ohm (honda ones) and 10ohm (what people wire in line) I guess it would work.
But if it doesn't and something blows don't blame me
[Modified by b3435, 1:31 AM 3/28/2003]
Old Mar 27, 2003 | 05:08 PM
tegasaurus's Avatar
Default Re: Mitsubishi resistor box? (b3435)
I'm going to wire in 10ohm resistors to my DSM 450s. I have a few qustions that maybe you can answer:
1) i know you can get them at radio shack or whatever... but do i just get just a regular ol 10ohm resistors or isn't there something liek 10ohms @ 30volts or 12 volts etc... something like that?
2)Which wire(s) do i wire them into? Its the yellow wire right? or is it the yellow w/ black stripe?
Thanks a ton,
Ryan
Old Mar 27, 2003 | 05:32 PM
HXMan's Avatar
Default Re: Mitsubishi resistor box? (tegasaurus)
Thanks a ton,
Ryan
Resistance is resistance, voltage doesn't change the resistance. The only thing that would change is the voltage drop, and power consumed.
Old Mar 27, 2003 | 05:36 PM
baphomet's Avatar
I have never done it but I have read how to do it several times ... Anyway, according to http://homemadeturbo.com/tech_projec...ors/index.html
On each injector you have a yellow/black wire. This is the power wire from the ECU. This voltage is constant and needs to be regulated, thus using a inline resistor. We have used 10watt 10ohm inline resistors from radio shack, they cost about 5 bucks for 4 of them. (packs of 2) Cut each wire (one at a time) strip the wire back and twist the wire around the resistor wire. I highly recommend using solder on this connection, as shown. Then tape up each resistor really good with some electrical tape.
here is a pic
Heres another link https://honda-tech.com/zerothread?id=392908
Hope this helps, check out those links to double check what I quoted if you haven't already, they have some good info.
092eg6
Feb 11, 2010 09:00 PM
d16racer
Apr 2, 2006 11:40 PM
asianspeed
Mar 23, 2003 01:24 PM
genop
Nov 20, 2002 08:21 AM
ion_four
Jun 4, 2002 04:58 PM
