Mitsu #8 turbine ?
Old Jul 22, 2002 | 04:05 AM
Hondakiller's Avatar
Default Mitsu #8 turbine ?
Does any use a #8 mitsu turbine ? I know its a little bit big but will this work on a highly moded 2000cc engine ?
Thanks
Old Jul 22, 2002 | 05:09 AM
Dee's Avatar
Dee
Default Re: Mitsu #8 turbine ? (Hondakiller)
What is a #8 turbo? T88? TD08? 8cm(3) ex housing? Please rephrase your question so that it can be answered!
A T88 with the correct exhaust housing can be used on a 2.0 liter motor. T78/TD08/T88 have been successfully used on SR20DET, RB20DET, 3SGTE, 1G-GTE, 4G93, FJ20DET, CA18DET and many other engines for years over here. Stephen Papadakis uses a T88 on his race motor.
[Modified by Dee, 9:37 AM 7/22/2002]
Old Jul 22, 2002 | 10:55 AM
Default Re: Mitsu #8 turbine ? (Dee)
Its a mitsu -Garrett turbo with 55mm wheel exduser
The front side is a 0.70 A/R with a 58 mm induser
Kenne Bell sells this as "jimmy 2 turbo " ,good for 500hp may be more
Ive got two of them and there are two guys that wants to buy them
One of them has a 99 Honda civic and the other one has a opel calibra turbo
Old Jul 22, 2002 | 03:15 PM
Dee's Avatar
Dee
It sounds like you have one of the TD06 hybrids! Isn't it kind of difficult to sell something when you know very little about it?
Old Jul 22, 2002 | 08:09 PM
Well this turbine is the stock for my truck which is a Syclone
When stock it worked till 4400 rpm and it is known that it was too small for 4300cc
So it will be fine for a 2000 cc engine that revs up to 8-8500 rpm
Modifications were never easy but i am used to it since i did my first turbo mod 13 years ago.Man i got 4 spining tires.......
Thanks
92civicx
Aug 27, 2007 10:39 PM
_Endless_
Feb 25, 2003 10:39 PM
crxgurlllll
17
Mar 19, 2002 10:26 AM
TurboT
Dec 13, 2001 09:50 AM
HX_Guy
Sep 28, 2001 04:05 PM
