missing a part from my full race traction bars?
I think i am missing what is circled as I just opened up mine and it doesnt have them in there. I got that pic from one installed in april 05...is there a new design out which doesn't use that now? How does the radius rod bolt onto the lca without that?
yeah they changed that design cause i think a few cracked.
u should hae a little piece that looks like this
the picture you posted are of our old CRX/EF traction bars. We have since changed the mounting to the new style, as it is much stiffer and provides a more accurate wheelpath.
the radius rod itself has two heim joints, one with a big hole, one with a small hole. The small hole goes to the crossmember, the big hole gets the steel spacer inserts, and the bracket bolts them to the LCA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff »</TD></TR><TR><TD CLASS="quote"> We have since changed the mounting to the new style, as it is much stiffer and provides a more accurate wheelpath.</TD></TR></TABLE>
Can you please post a picture of that linkage? I have some Z-10 bars but I'd be happy to get rid of them if I could find some bars that maintain correct suspension geometry when the lower control arm moves up and down. The car is a '99 Si (EM1).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">
The car is a '99 Si (EM1).</TD></TR></TABLE>
this thread and the mounts that we are referring to only pertain to 88-91 Civics/CRXs
For your 99EM1, the suspension geometry is the difference between ours and Z10s.
This is another thing on my list of “things I can’t say enough good about” Rodger you will not be disappointed well worth the money. by the way did you decide not to run the dart 2liter motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">This is another thing on my list of “things I can’t say enough good about” Rodger you will not be disappointed well worth the money. by the way did you decide not to run the dart 2liter motor?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1518026
