Missing Link MAP, missing red O rings....
Old Jul 8, 2002 | 11:07 PM
Tofurky's Avatar
Default Missing Link MAP, missing red O rings....
i'm almost done with everything on the dragIII install... just gotta double check all the lines and figure out this...
i should've checked when i got the parts back, but i didn't. I'm missing the 2 red O rings from the missing link, and i believe there was a plastic piece inside as well that i'm missing. but i'm not sure about that one. Will it work without the 2 red O rings or Will my car run(well) without the missing link at all. and if i'm missing that stuff, am i gonna have to just buy a whole new one?
any help would be appreciated
-erik
Old Jul 8, 2002 | 11:12 PM
ion_four's Avatar
Default Re: Missing Link MAP, missing red O rings.... (Ruckus138)
car won't run without missing link (unless you're using the afc) I'd say that you should get the o-rings at a good hardware store. I couldn't tell you about the plastice part, though. Good luck, from a fellow Erik.
Old Jul 9, 2002 | 12:14 AM
Mr. Softee's Avatar
Default Re: Missing Link MAP, missing red O rings.... (ion_four)
it will run without the missing link, barely... you'll backfire like crazy and the car will run like total ****.
Old Jul 9, 2002 | 04:37 AM
turbo Si's Avatar
Default Re: Missing Link MAP, missing red O rings.... (94goldjungsr)
Go go to the hardware store and buy 2 o-rings. Problem solved!
D15Bbigred
Feb 21, 2006 07:57 AM
TheIntegraGuy
Jul 15, 2005 08:37 AM
Treblarefils
Feb 23, 2005 11:26 AM
Soccerking3000
Sep 7, 2004 09:00 AM
turboturd98
Dec 24, 2003 07:49 PM
