misfire!!!what could be the prob??
Old Nov 5, 2003 | 07:43 PM
boost fed ls's Avatar
Default misfire!!!what could be the prob??
i have been getting misfiring codes in cyl.1,2,3,4 what could be causing the problem. my set up is garrett t3/t04e running afc hack with 450.
Old Nov 6, 2003 | 01:51 AM
Default Re: misfire!!!what could be the prob?? (jdm2916)
anyone?????????
Old Nov 17, 2003 | 08:14 PM
ntegls's Avatar
bump
Old Nov 17, 2003 | 08:17 PM
TurboB18C1's Avatar
Default Re: misfire!!!what could be the prob?? (boost fed ls)
How does your plugs look like?
rjardy's Avatar
Default Re: misfire!!!what could be the prob?? (TurboB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">How does your plugs look like? </TD></TR></TABLE>
engrish?
Rob
Old Nov 17, 2003 | 08:23 PM
tegmech's Avatar
are the plugs fouled???
Old Nov 17, 2003 | 09:34 PM
senpai's Avatar
You're running too rich ... I bet his plugs are soaked with fuel
Old Nov 17, 2003 | 10:15 PM
V-SPEC 1's Avatar
Default Re: misfire!!!what could be the prob?? (maztur)
Blown head gasket.
Old Nov 17, 2003 | 10:47 PM
S2KP's Avatar
I had the same problem, check your plugs they're most likely foul out..
Old Nov 17, 2003 | 11:18 PM
NuclearB18B's Avatar
Default Re: (Turbo_Siii)
i have the same problem...it's because you're running too rich. will be fixxed very soon...it's hondata time
Old Nov 29, 2003 | 11:33 AM
Default Re: (ha illuminato un)
yes the car is running ruch, can the miss-fire cause the car to run bad
Old Nov 29, 2003 | 11:35 AM
laughinxxx's Avatar
New User
Default Re: (boost fed ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls &raquo;</TD></TR><TR><TD CLASS="quote">yes the car is running ruch, can the miss-fire cause the car to run bad</TD></TR></TABLE>
Oh yeah. Misfire is very noticeable.
Old Nov 29, 2003 | 12:02 PM
Default Re: (laughinxxx)
is it a decrease in performance, buckung, ect could you please decribe it please!!
EngineNoO9
Honda Motorcycles
13
Nov 8, 2008 07:05 AM
J.nguyen
Sep 23, 2006 01:07 PM
fanta!
Aug 10, 2005 04:13 PM
PUREVIL
Nov 20, 2003 04:53 PM
KooK
Oct 19, 2003 10:13 PM
