misfire issue
Old Oct 14, 2012 | 02:57 PM
Cmorcivic's Avatar
Default misfire issue
93 hatch B18b1 with obd1 s300
Misfire started out as an issue only during warm starts and has progressed to doing it all the time. No CEL. Car is running very lean according to my AEM wideband which was not the case before. Also all 4 plugs are slightly white which agrees with the wideband.
Things I have tried so far:
Changed plugs
changed dist. cap, rotor, and external coil
new plug wires and coil wire
replaced gas tank (it had a leak)
checked fuel pump
fuel pressure is 50psi at filter
replaced filter
stiffer spring in BOV
Turbo still makes boost
unplugged MAP sensor car would not start
unplugged ECT sensor car ran worse
removed vacuum line from FPR and car ran smoother but still lean
in Smanager added 40% to fuel trim which put the AFR almost dead on but still had misfire
could not find any boost/vacuum leaks
Old Oct 14, 2012 | 03:55 PM
Jules804's Avatar
Default Re: misfire issue
you need to take your car to a tuner asap, also check make sure your injectors are working properly and check your timing as well
Old Oct 14, 2012 | 04:21 PM
Cmorcivic's Avatar
The car was dyno tuned for the current setup. What's the best way to check the injectors and timing? Thanks for the help. Also know of any good shops in or near DE?
Old Oct 14, 2012 | 05:03 PM
Cmorcivic's Avatar
To make things more interesting just went out started it and it worked perfect from a cold start. Any ideas?
Champs32
10
May 25, 2010 06:14 AM
Flashmn
Jun 15, 2008 05:15 AM
igo4bmx
Jul 30, 2005 06:50 AM
ScandalousCivic
May 12, 2005 07:42 AM
ScandalousCivic
May 10, 2005 06:20 PM
