Minor bug on my new build
Old May 31, 2006 | 12:15 PM
Boostage's Avatar
Default Minor bug on my new build
Motor:
AEM EMS
B16 motor
Jg Intake
Darton Sleeves
pauter rods
wiseco Pistons
New Honda everything (pumps bearinsg etc)
Problem:
While at idle trying to setup limiters in the basemap. temp on the laptop went well over 200*. stock temp needle was not even at the middle (thanks for the totally inaccurate guage honda *grrr*) anyway the upper radiator hose was Hot and hard ( full of coolant) the lower radiator hose was ice cold. So we figured the thermostat just wasnt opening ( although brand new) anyway I ran to pepboys bought another one and put it in there. same thing.
No way two new stats could be bad. Then it occoured to me.. if the upper radiator hose is hot. obviously the heat is coming from the engine. but how? the lower was soft and cold as ice. it cant be coming back thru the upper hose??
Old May 31, 2006 | 12:19 PM
DaveF's Avatar
Default Re: Minor bug on my new build (Boostage)
air bubble
Old May 31, 2006 | 12:21 PM
Boostage's Avatar
Default Re: Minor bug on my new build (dturbocivic)
We Bled the air out of the system, sorry forgot to mention that.
Old May 31, 2006 | 12:24 PM
Mase's Avatar
water pump working?
when u bleed the coolant system.
did you have the heat on high and let it idle for a few minutes?
btw, the honda gauges work, they are designed not to go up until it gets hot like 225-230 degrees...
Old May 31, 2006 | 12:45 PM
Boostage's Avatar
Default Re: Minor bug on my new build (Mase)
Yes tried with the heater on, same ****.
Old May 31, 2006 | 12:53 PM
RTW DC2R's Avatar
does the fan come on?
Old May 31, 2006 | 01:02 PM
Boostage's Avatar
Default Re: (clip the apex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clip the apex &raquo;</TD></TR><TR><TD CLASS="quote">does the fan come on? </TD></TR></TABLE>
Yes
Old May 31, 2006 | 03:06 PM
DaveF's Avatar
Default Re: (Boostage)
do you have the hose that loop from the thermo housing to the intake manifold hooked up ?
Old May 31, 2006 | 03:40 PM
postman's Avatar
incorrect thermostat for setup maybe one with softer spring. try maybe not even runnong the thermostat once, then check to see if the temps keep going up
dbailey
11
Jan 30, 2020 04:27 AM
Rylan
22
Mar 15, 2011 12:40 PM
90crxdxb16
26
Aug 10, 2007 04:06 AM
animalchin32
Jul 8, 2005 06:35 PM
DRKSol
Jun 6, 2005 04:51 AM
