melted pistons
Old Feb 24, 2010 | 09:51 PM
  #26
Glove's Avatar
Default Re: melted pistons
new tuner is required
Old Feb 24, 2010 | 10:29 PM
  #27
ralph11sec's Avatar
ii think the 30 degrees was his base timing.
what we want to know is what is the ign timing you have on your WOT.
with 91-93 octane, whats your IAT? did you do plug readings on the other cylinders after the BOOM?
you should only be hitting 300hp or so with 93 octane. 400 is a bit pushing it.
Old Feb 24, 2010 | 10:48 PM
  #28
94GSRMR's Avatar
maybe around 330hp with 93
Old Feb 25, 2010 | 03:08 AM
  #29
99JDMHATCH's Avatar
Who was your tuner so when I come back home to FL I know to avoid him.
Old Feb 25, 2010 | 03:32 AM
  #30
tepid1's Avatar
Tell you what.... I am still a mod over on the Neptune forums. You can post your file there or you can email it to me so I can take a look at it. If you want to email the cal file send it to: tepid1@sbcglobal.net
Old Feb 25, 2010 | 04:16 AM
  #31
b20beast83's Avatar
How much is recommended on 91oct
Old Feb 25, 2010 | 04:46 AM
  #32
94GSRMR's Avatar
yeah i want to kno who your tuner was so i can avoid them
Old Feb 25, 2010 | 08:35 AM
  #33
jprelude92's Avatar
where in fl do you live i live in ft myers
Old Feb 25, 2010 | 08:38 AM
  #34
jprelude92's Avatar
timing was 30 degrees at idle and he said he had it at 21 degrees on his lap top by the way i'm running hondata s200.
Old Feb 25, 2010 | 08:39 AM
  #35
jprelude92's Avatar
i'm gonna have the injectors flow tested just to make sure they ok thats what the tuner wants me to do
Old Feb 25, 2010 | 08:41 AM
  #36
jprelude92's Avatar
i'm not gonna disclose his name and the name of his shop until i'm possitive it was his fault
Old Feb 25, 2010 | 08:42 AM
  #37
jprelude92's Avatar
my car was pushing 320whp at 14 psi but yesterday when it blew up it was running 12psi
Old Feb 25, 2010 | 08:43 AM
  #38
jprelude92's Avatar
im gonna try to get the file and email to you i jsut hope he didnt change anything
Old Feb 25, 2010 | 08:44 AM
  #39
Schister66's Avatar
Man U FTW
That sucks dude. Its too bad that there is a no-fault policy for tuners when at times, not that this is definitively one of those times, it IS their fault.
Old Feb 25, 2010 | 09:01 AM
  #40
vtekthis's Avatar
detonation homie, too much timing or **** fuel, pre ignite will go after the center of the piston
Old Feb 25, 2010 | 09:18 AM
  #41
Glove's Avatar
30 degree's at idle?? what in the hell?
Old Feb 25, 2010 | 09:23 AM
  #42
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Don't waste your time and money flow testing the injectors, if that were the cause, you would have only one piston damaged. If by some miracle all 4 injectors were not flowing properly, then the tuner obviously would have noticed improper AFR...
...and by the way, don't be scared to say who tuned the car. There is nothing wrong with saying who tuned the car, whether or not he is the cause of the failure. It would be wrong to say "so and so" blew my motor, yes, but until you are certain of that, there is no harm in saying who did the work for you... You did after all pay him for a service.
Just think, right now there could be a person getting his pride and joy tuned by this same person tomorrow, he may have seen this thread, and won't be informed of a possible issue with the guy. Look at it this way, you would want to be informed wouldn't you?
Old Feb 25, 2010 | 09:57 AM
  #43
vtekthis's Avatar
plus there is a ton more reasons why it could have detonated NOT being the "tuners fault" (well he should have noticed before he proceeded.)
what did the batt voltage look like when it melted down? what fuel pump is on the car?what injectors? what was the coolent temp? what was the total timing at the boost level u were runnning? was the any comps tables active when it melted down?
was the motor syned with the ECU? is there a stock distributer on this car? what ecu? i think i heard neptune?
there is soooooo many things that could have happened here....
Old Feb 25, 2010 | 09:59 AM
  #44
vtekthis's Avatar
not too uncommom with a big injector car, nor with a exotic fuel either... but pump gas ? a little extremeIMO
Old Feb 25, 2010 | 10:02 AM
  #45
jprelude92's Avatar
i guess your right the name of the shop is tuning tricks in ft myers florida an the tuners name is Todd
Old Feb 25, 2010 | 10:05 AM
  #46
jprelude92's Avatar
i dont know if it matters but the car ran 10 AFR on WOT a few times when he was tuning it
Old Feb 25, 2010 | 10:06 AM
  #47
Glove's Avatar
30 degrees on pump gas...
That guy just stole your money, and slapped you in the face, and then put salt and alchahol on your wounds
  #48
tepid1's Avatar
I use to run high timing at idle too.... for many reasons. Never had this problem though....
Old Feb 25, 2010 | 10:08 AM
  #49
vtekthis's Avatar
[quote=I CRX I;41688068]it may have been 30* at MBT, not base timing.[/quote
A MBT of 30 deg on pump gas @1 bar, would do very quickly what it did in those pic
Old Feb 25, 2010 | 10:09 AM
  #50
vtekthis's Avatar
AFR dont mean **** if there is too much timing, throw in as much fuel as you want ull still end up with ur motor at the end of the day
