Max Rev manifold + fans.. ??
Old Jan 12, 2002 | 08:33 PM
dustin's Avatar
Default Max Rev manifold + fans.. ??
Ok, I'm finally installing my max rev manifold... how did you guys get the turbo to clear your rad fans ? The manifold positions the turbo so far out that not even my FAL fans fit (In fact, I had to yank the fans out just to test fit the manifold...)
Dustin
Old Jan 12, 2002 | 08:35 PM
LsTurbo91's Avatar
Default Re: Max Rev manifold + fans.. ?? (dustin)
the fan near the AC compressor I mounted in front. I had no problems clearing the main fan. I have el cheapo Autozone Fans. Your barely getting the manifold on? How come the long downtime?
Old Jan 12, 2002 | 08:38 PM
dustin's Avatar
Default Re: Max Rev manifold + fans.. ?? (LsTurbo91)
I haven't had time (or a welder) to fix it until now
I can't really mount my fal fans in front.. they're once piece.
Dustin
Old Jan 12, 2002 | 08:55 PM
LsTurbo91's Avatar
Dustin
what did you need to weld? the downpipe?
ouch about the fal fans. I'll trade you if you want! I got a 12" and a 10" autozone fan seperate!!
Old Jan 12, 2002 | 09:30 PM
dustin's Avatar
Hmm, ok well I just took the condenser out. Hehe. I'm taking the entire A/C system out.
Mounting the fal fans on the front and reversing fan polarity.... I think I'll wire the two fans together so they both run.
Dustin
Old Jan 12, 2002 | 09:31 PM
dustin's Avatar
Downpipe, dumptube, closed loop system.
In addition to a bunch of other things But yes, mainly the downpipe.
Dustin
Old Jan 12, 2002 | 09:45 PM
LsTurbo91's Avatar
Dustin
I also had to flip the blade and run reverse polarity like you mentioned.
Old Jan 12, 2002 | 10:14 PM
Arturbo's Avatar
Better than steak
25 Year Member
Dont do the weak surface tig welds, like Ive seen on the downpipes we first made. We corrected that problem also on the new downpipes.
Old Jan 12, 2002 | 11:12 PM
turbocoupe's Avatar
Default Re: Max Rev manifold + fans.. ?? (Arturbo)
closed loop system
Old Jan 12, 2002 | 11:52 PM
lucas569's Avatar
dustin is this in your GSR or crx? (dumb ? i know)
Old Jan 13, 2002 | 02:01 AM
dustin's Avatar
My welds have full penetration
Dustin
Old Jan 13, 2002 | 02:16 AM
Arturbo's Avatar
Better than steak
25 Year Member
Dustin
Kinky eh? I guess thats why they call it "forced induction."
art
Old Jan 13, 2002 | 10:26 AM
lucas569's Avatar
dustin you have new pics? i know you like to document your entire LIFE!
post a sound clip of that new bov you asap,i bought one too...
Old Jan 13, 2002 | 11:30 AM
98hx99b18c's Avatar
Default Re: Max Rev manifold + fans.. ?? (lucas569)
Thats wierd both my fans radiator and a/c have good clearance. BTW gsr in a civic coupe.
Old Jan 13, 2002 | 11:43 AM
dustin's Avatar
Default Re: Max Rev manifold + fans.. ?? (98hx99b18c)
There must be some difference between the motor->radiator clearance with GSR in civic chassis then....
Dustin
Old Jan 13, 2002 | 01:04 PM
01geeser's Avatar
New User
try askin turbot he had it in a itr
Old Jan 13, 2002 | 03:08 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Max Rev manifold + fans.. ?? (01geeser)
Dustin
How much room is there needed to fit the turbo and the fal fans the way they are ment to be sitting. I'm asking because I have the same setup as you so I know what i'm gona run in to....
Oh by the way are the fal fans pushers or pullers???
Adi
Old Jan 13, 2002 | 04:34 PM
SlowTeg's Avatar
Default Re: Max Rev manifold + fans.. ?? (newgsr)
Well, if you mount the fans inside the engine bay where the stock fans mount, you should buy a puller. If you mount it on the other side where the ac condenser would be, than you should get a pusher.
I'm also curious how much space there is with the maxrev manifold in an integra, for clearing the a/c fan. Are the fal fans too deep? Anyone got theirs on yet?
-Mike
Old Jan 13, 2002 | 05:40 PM
1's Avatar
Default Re: Max Rev manifold + fans.. ?? (SlowTeg)
Fans can be a puller or pusher that's why Dustin mentioned reversing the polarity.
Old Jan 13, 2002 | 10:24 PM
dustin's Avatar
Default Re: Max Rev manifold + fans.. ?? (1)
Well, since the AC is out I went and bought some 3" mandrel bends and I'm making a full 3" DP
Dustin
Old Jan 13, 2002 | 10:27 PM
lucas569's Avatar
dude your up late!
Old Jan 14, 2002 | 01:08 AM
dustin's Avatar
Ahh, I just tack welded the dp piece that curves around under the oil pan in place... ahh the 3" DP fits!! haha. I am glad to be rid of that pesky AC compressor!
Gotta get my camera to take pics....
Old Jan 14, 2002 | 07:46 AM
lucas569's Avatar
just ignore me, i dont mind,just pretend i dont exist.
Old Jan 14, 2002 | 08:28 AM
Boosting73's Avatar
how does your maxrev manifold look like? Can you post a pic or a link of how it looks like? THanks
Old Jan 14, 2002 | 09:14 AM
brian b's Avatar
New User
Default Re: Max Rev manifold + fans.. ?? (Boosting73)
my maxrev manifold fits with both fans intact (radiator one slightly cut) cause the turbo basicly sits between them in a 00 civic si (i know it fits differently with a gsr motor/civic and also an integra)
1320king
Mar 11, 2013 06:03 PM
4gencivicef9
Jan 1, 2009 08:47 PM
Waggy
Feb 27, 2007 05:40 AM
accordfreak
Nov 4, 2003 03:27 PM
