max bore/boost
Old Jun 10, 2004 | 06:19 PM
2k.civic.si's Avatar
Default max bore/boost
whats the max bore i can safely take my b18b to...how much boost can i run at this bore?
currently i have proline crank...scat rods....toga bearings....havnt ordered the pistons unsure on bore....
i already bored the block to 81.5...originally was gonna run ctr pistons and go n/a...but got a gsr block instead....now im gonna build this b18b for turbo
Old Jun 11, 2004 | 01:32 AM
Default Re: max bore/boost (2k.civic.si)
thanks for the help.
Old Jun 11, 2004 | 01:36 AM
Jared's Avatar
81.5 is the most you're gonna want to run with stock sleeves
Old Jun 11, 2004 | 07:14 AM
Joseph Davis's Avatar
Default Re: max bore/boost (Jared)
I've heard 81.25mm for boost, save the 81.5mm for NA. That's internet wisdom for you, I've also been told I need spinnaz for my CRX so take it with a grain of salt.
With how thin the stock sleeves are between the ribbings, my personal choice would be to try to get away with stock bore and glaze break hone if I could. A quarter millimeter is a significant thickness with how thin shizzle is in this area.
90SiHatchy
Apr 9, 2011 05:13 AM
jdmlude87
Apr 3, 2009 01:19 PM
SpoolnByYou
Dec 19, 2005 02:28 PM
B18 CYA
Apr 7, 2004 03:43 PM
savannakhet
Feb 26, 2003 03:35 PM
