Max boost w/stock internals
Old Feb 6, 2003 | 11:47 PM
greddyturboGSR's Avatar
Default Max boost w/stock internals
I have a 99 GSr with a greddy kit, intercooled, still running the blue box. Right now im boosting .68 bar. Not sure exactly what that converts to (psi). Now much boost do you guys think I can safely run on stock internals?? Also, im not hearing any detonation but should I look into retarding my ignition??
Thanx for the help
Old Feb 7, 2003 | 12:09 AM
Default Re: Max boost w/stock internals (greddyturboGSR)
anyone??
Old Feb 7, 2003 | 12:16 AM
PureTeg420's Avatar
your running nearly 10 psi right now....your asking for trouble using greddy's fuel management.
Old Feb 7, 2003 | 12:55 AM
Default Re: Max boost w/stock internals (PureTeg420)
then I better learn how to use my apex avc-r soon because I have been boosting .68 bar for a couple months now.
Old Feb 7, 2003 | 03:59 AM
MyWhiteCivic's Avatar
I run 10 lbs all day on my D16Z6 but I have Hondata.
Old Feb 7, 2003 | 05:28 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Max boost w/stock internals (MyWhiteCivic)
The greddy keeps boost @ that stock with an IC (Actually a little lower). If you are running the FCU then you should be okay (for a little while). I'd get it tuned with a Hondata in the near future
Old Mar 8, 2003 | 06:26 AM
integra6650's Avatar
Default Re: Max boost w/stock internals (Apex i ITR)
so you think i could run 10 lbs on stock internals on my b18c1 tuned with aem ems avcr ignition and fuel settup
Old Mar 8, 2003 | 06:40 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Max boost w/stock internals (integra6650)
I'm not sure but i believe the Greddy FCU does all th ignition as well. I may be wrong. That's what i was told a while back by a greddy dealer.
Old Mar 8, 2003 | 06:53 AM
b16ahybrid's Avatar
Definatly....
406EVO
Engine Management and Tuning
Oct 18, 2011 10:39 AM
89civicsiB18B
May 14, 2005 07:56 AM
blacksi-t
Dec 8, 2003 06:08 AM
Andrew 825SM
Sep 20, 2002 10:27 PM
turbo_b18c
Sep 12, 2001 04:25 PM
