Max boost for GSR vs Nos
Old May 27, 2004 | 03:31 AM
warhorse 4.6's Avatar
Default Max boost for GSR vs Nos
Hey guy what is the most boost or spraying can a stock GSR take with a safe tune. And how much power will it make to the front wheel?? My cuz has a intag and i would like to know what is the max amount he can spary on his zex kit vs boost. For may car which is a 4.6 stang 150 shot is the max you can go and be safe. And some are runing 12 pounds of boost on a dam good tune. 8psi to 12psi=390 to 500rwhp range and the same in TQ some blower make more power then others same for Nos kits. Thank you
Old May 27, 2004 | 10:07 AM
nevin's Avatar
Default Re: Max boost for GSR vs Nos (warhorse 4.6)
depends on how its tuned and how long you want it to last. inline pro has made 450(i think) on stock gsr motors with the exception of thicker headgasket and arps. once at these powerlevels however if your motor detonated you can kiss it goodbye
Old May 27, 2004 | 10:22 AM
gelok's Avatar
Default Re: Max boost for GSR vs Nos (nevin)
He can boost up to 10 psi w/ proper tuning and probably make 300+whp I made 252whp at only 6psi when I had my turbo setup
Old May 27, 2004 | 11:36 AM
GSRwBOOST's Avatar
Default Re: Max boost for GSR vs Nos (B-18-C1)
was he speaking english when he wrote that?
Old May 27, 2004 | 12:16 PM
nevin's Avatar
Default Re: Max boost for GSR vs Nos (GSRwBOOST)
i was going to reply with "english?" but decided to be nice
Old May 27, 2004 | 08:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-18-C1 &raquo;</TD></TR><TR><TD CLASS="quote">He can boost up to 10 psi w/ proper tuning and probably make 300+whp I made 252whp at only 6psi when I had my turbo setup </TD></TR></TABLE> Dam that is a lot of power man. 254whp off of 6 pounds of boost is not bad at all. How much torque do you make and at what rpm does it paek at???
Old May 27, 2004 | 08:44 PM
Mad Cow's Avatar
Old May 27, 2004 | 09:20 PM
gelok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warhorse 4.6 &raquo;</TD></TR><TR><TD CLASS="quote"> Dam that is a lot of power man. 254whp off of 6 pounds of boost is not bad at all. How much torque do you make and at what rpm does it paek at??? </TD></TR></TABLE> thanks! It made 180wtq and it peak at 8k rpm
Old May 28, 2004 | 03:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-18-C1 &raquo;</TD></TR><TR><TD CLASS="quote"> thanks! It made 180wtq and it peak at 8k rpm </TD></TR></TABLE> Nice numbers man the B-18 motor is the hot ticket i see. Do you think the RSX motor will be as hot as the B-18 motor is when the price comes down on them??? MY car is in the shop geting a paint job and a new drop top I just put in new blower cams. But the last time at the dyno it made 390rwhp and 387rwtq on 8psi. My cams with a tune should put me at 400+rwhp but my torque will stay the same. Any way thank you for the info
Nucking Futz
Aug 12, 2011 10:41 PM
Chico Suave
May 23, 2009 07:49 AM
themurrell
Jun 4, 2007 06:29 PM
Doogie Howser
Jul 27, 2002 10:09 AM
Thrillhouse
May 16, 2002 10:00 PM
