Marosso oil pan
Old Mar 23, 2009 | 07:21 PM
sanman000719's Avatar
Default Marosso oil pan
anyone else running this oil pan setup. I have been using it for a year now, and went through 3 motors. It took a year to diagnose that something in this setup wasnt allowing oil pressure to be built up like it should be. We went to a OEM GSR pan, and pick up tube, and walla oil pressure is there now with no oil light flicker.
so anyone else using this setup, and having any issues??????
Old Mar 23, 2009 | 07:27 PM
kyden's Avatar
Default Re: Marosso oil pan
were you using the correct pickup tube?
Old Mar 23, 2009 | 07:36 PM
yes the correct pick up tube was being used
we had been having the oil light flicker for a long time now, and i was told it was brittle wiring, but I recently had a rod bearing get really worn, and after doing the bearing it was still doing it so my tuner wasnt happy. they changed the pan/pickup tube and all is well now. They use the same setup on there drag car with everything down to the "T" .
Old Mar 23, 2009 | 07:45 PM
grndcont's Avatar
what pan were you runing? i just recived my moroso pan today. it's the 4qrt one, 20911. I've read alot of posts about these pans saying they leak and what not, i hope my results are better than the rest.
Old Mar 23, 2009 | 07:56 PM
I think it was the 6qt pan in fact im sure it was
i am sold the pickup was having issues, but i opted to just nix it all togather and go back to oem
Mine didnt leak at all to be quite honest did have an issue at the drain plug but i solved that
Old Mar 24, 2009 | 01:58 AM
96 GSR-T's Avatar
No issues with my steel moroso, my oil pressure is more than adequate according to my gauge.
Old Mar 24, 2009 | 06:53 AM
donno like i said we were getting very low oil pressure from the morroso setup, and switched it out for a OEM pan and pick and walla all is well on the home front.
so by process of elimination, and about 15k bux later were good lol thank god
Old Mar 24, 2009 | 06:55 AM
Eran's Avatar
HT White Ops
You starved three motors of oil before you went looking for a problem?
Old Mar 24, 2009 | 07:12 AM
ok first of all i paid quite a bit of money for a setup, and felt it wasnt up to me to figure it out its the shops that got paid, and not everyone is a mechanic lol. I am learning though. Since im n ot a highly skilled mechanic, and I was investing 17k to a setup right off the batt I felt it was better for me to get a shop to do my setup that would last rather than me, and have it not last hope that makes sence
Old Mar 24, 2009 | 10:50 AM
purpleh22's Avatar
My 6qt. Morosso and pickup work fine except for some oil weeping. I'm putting on new seals after double checking and cleaning up the mating/gasket area. No oil pressure probs except hard right cornering when oil is down 1/2 qt or so. For drags - no cavitation or oil starvation at all.
Old Mar 24, 2009 | 12:31 PM
well ok im sorry for this post it seems this wasnt the issue the car hit the rollers, and well same issue I was told it was the pan and the OEM solved it.
my Morroso was never an issue at all, it had a leak from the drain plug that i added another washer wich solved it.
Old Mar 24, 2009 | 03:31 PM
96 GSR-T's Avatar
So your saying a leaky drain bolt caused you to have low oil pressure?
Old Mar 24, 2009 | 03:47 PM
Warhawk's Avatar
no, he said that was the only problem he had with the marosso and he managed to fix the problem anyway. Now he is back to square one because he is having the same problem with an OEM pan.
Old Mar 24, 2009 | 05:28 PM
correct it has been narrowed down to oil squirters we are thinking one is loose causing the loss of pressure
Old Mar 24, 2009 | 07:30 PM
wpgredteg's Avatar
well im glad that you posted that it wasn't the fault of the pan as nobody has every had an oil pressure problem just because of the pan. usually lack of oil, blockages, etc.
Old Mar 24, 2009 | 07:33 PM
220 ek9's Avatar
well mind wrks find.. i have the 6qrts one
STN_Pat
Nov 29, 2012 04:05 AM
ATS*Mark
48
Feb 11, 2007 03:45 PM
WalkerGSR1
Jan 4, 2007 07:31 PM
rival12
Sep 20, 2005 04:29 PM
