Map Voltage in PSI
Old Dec 17, 2007 | 07:40 AM
Fred931931's Avatar
Default Map Voltage in PSI
Hi , Im just wondering if anyone had this info.. on a stock y8 map sensor.. What is Voltage/PSI chart... ? i know it top at about 12 PSi and ist doing 0 to 5 Volt.. but i need something more accurate.... TX in advance for any info..
Old Dec 17, 2007 | 07:49 AM
DaveF's Avatar
Default Re: Map Voltage in PSI (Fred931931)
it should be rather easy to figure out with a few tools + some compressed air.
Old Jan 20, 2008 | 03:48 PM
rnbguy's Avatar
im looking for this info too, could you save me having to do the above by listing your findings please?
Old Jan 20, 2008 | 03:55 PM
ej8's Avatar
ej8
Default Re: Map Voltage in PSI (rnbguy)
its in the helm manual
Old Jan 21, 2008 | 02:56 AM
rnbguy's Avatar
Default Re: Map Voltage in PSI (ej8)
i dont have a copy of the helm, can someone share please?
Old Jan 22, 2008 | 04:45 PM
ej8's Avatar
ej8
https://honda-tech.com/zerothread?id=789742
Old Jan 22, 2008 | 05:26 PM
97grnrs's Avatar
i did this test not too long ago.. @ 11 psi the 92- up map sensors stopped producing voltage. lke 4.78 V at like 10.8 psi or so was the limit. it wouldnt go any higher with more air press
Old Feb 4, 2008 | 02:50 PM
rnbguy's Avatar
Default Re: Map Voltage in PSI (97grnrs)
thanx for the link
Old Feb 4, 2008 | 03:20 PM
Joseph Davis's Avatar
ej8, you do not suck as a person.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i did this test not too long ago.. @ 11 psi the 92- up map sensors stopped producing voltage. lke 4.78 V at like 10.8 psi or so was the limit. it wouldnt go any higher with more air press </TD></TR></TABLE>
You had an OBD1+ MAP, the 85-91 OBD0 MAP only reads up to 9.25 psi, otherwise is identical.
joy123
14
Feb 11, 2015 04:06 PM
hatchBK4life
Feb 3, 2010 12:08 PM
Raf
Feb 25, 2005 07:54 AM
LostCRX
Jul 7, 2004 05:07 AM
