MAP sensor went off!!
Old Jun 7, 2004 | 05:42 PM
pa2play's Avatar
Default MAP sensor went off!!
Ok, just got done with my Homemade turbo, d16, t25, 450 injectors, S-afc,8 psi, my settings are lo -36% and hi -35% all the way across. I was told that from a dyno that was way to lean and I was in too much vacum, but everyone else says that's rich. Anyways, I was cruising on the highway at 70 mph, not boosting, and my map sensor code came on. any suggestions. Then I reset the ECU, set my afc at lo -35% going down to
-25% as the rpms went up to 8000 rpm's. my hi settings are now -34% going up to
-25% as the rpms go up to 8000rpms. The signal doesn't go on on the high way anymore, but now it overheats, but only when I'm going 55+ mph.
Modified by pa2play at 3:03 AM 6/8/2004
Tippyman
Engine Management and Tuning
Aug 8, 2013 06:52 PM
88crxdxfastwhip
Mar 13, 2006 06:35 PM
djwest24
May 19, 2004 09:29 AM
kell211
Mar 25, 2004 05:02 AM
