map sensor voltage???
Old Mar 24, 2004 | 03:28 PM
kell211's Avatar
Default map sensor voltage???
at what voltage does the stock map sensor throw a code when boosting? with the profec e-01, you can clamp the voltage, and then go in and up the fuel and/or injector duty cycles to get the extra gas. For that matter, if anyone could tell me the difference in changing the a/f adjustment map and injector duty cycles i would be immensely appreciative. sounds like the same thing to me, but they have different maps for each.
i'm currently running it hack style, but i'm going to make it to a dyno soon and was hoping to set it up this way. this way i was hopping to be able to make it up to 15psi safely, a/f wise. and advice or info is appreciated.
Old Mar 24, 2004 | 05:47 PM
kell211's Avatar
Default Re: map sensor voltage??? (kell211)
bump
Old Mar 24, 2004 | 07:28 PM
kpt4321's Avatar
~2.8 volts. I can't tell you exactly, so you may need to experiment a little bit. Just use a potentiometer to change the voltage with the car off and see if it throws a CE light.
Old Mar 25, 2004 | 05:02 AM
kell211's Avatar
Default Re: (kpt4321)
thanks, but what's a potentiometer and how much do they cost. anybody else know off hand?
Tippyman
Engine Management and Tuning
Aug 8, 2013 06:52 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
justinb
Jun 2, 2005 03:39 PM
dannydos
Dec 12, 2004 06:17 AM
JSpecwest
Jan 2, 2002 12:48 PM
