Map sensor question
Old Mar 30, 2004 | 03:29 AM
specktur's Avatar
Default Map sensor question
As I stated in my other post I am going turbo and I have a few questions.
This one is reguarding the map sensor. I found a MSD Map sensor for $35, they actually have a few versions out. anyone ever used one of these, http://www.msdignition.com/fuel_12.htm. anyway, Can I buy the 2 bar and use it on my civic?
Thanks,
Sean
Old Mar 30, 2004 | 04:13 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: Map sensor question (specktur)
you will need to get engine management that can read the 2bar or 3bar map sensor that you use. your stock ecu is set up for a 1bar map sensor and will have a field day throwing codes if you try to use anything else with it.
you'll either need a stand alone setup or some sort of piggyback that intercepts the new signal and then sends a fakey signal to the ecu.
Old Mar 30, 2004 | 04:52 AM
specktur's Avatar
Default Re: Map sensor question (stackz)
Thanks, thats kinda what I thought... So I would be able to use it with say hondata... Good to know.
Sean
Old Mar 30, 2004 | 05:31 AM
MiraiZ's Avatar
A Honda map sensor is not 1 bar...its actually closer 2bars...one bar vacuum and 11psi postive.
2Bar should really be good enough for the average booster (1bar vacuum 1 bar boost about 14.7 psi)
woojdm
Jun 9, 2009 08:54 PM
dseriesdrag
Sep 21, 2006 09:32 PM
Civicman86
Sep 21, 2006 08:25 PM
fast[R]
Jul 18, 2002 03:00 PM
