MAP Sensor Problem
Old Feb 2, 2004 | 11:47 AM
TurboLSVtecTeg's Avatar
Default MAP Sensor Problem
Ok well it really isnt a problem. The car runs great. But im getting the cel 05 which is MAP sensor.
I have V-AFC, 440's, FMU, and check valves. Now when i goto reset the ecu the code still comes on right away. Ive swapped ecu's and it still does the same thing. I will try and swap the sensor if i can find one. I would think that if i reset the ecu the CEL wouldnt come on until I start the car. BTW on the V-AFC sensor check with the ignition on and engine not running im at about 2.865v and with the engine idling im at about .95- 1v. It has all checked out and everything is hooked up right. But I cant seem to get rid of this code. I need to clear the check engine light so I can goto emissions. This is on a 98 gsr running a 98 Type R ecu and my stock 98 GSR ecu. The code just wont go away.
Old Feb 2, 2004 | 11:55 AM
Default Re: MAP Sensor Problem (TurboLSVtecTeg)
Nevermind I fixed the problem but now I have IAT sensor code. Anybody selling one??
HX35_Ek_Hatch
Jan 15, 2013 07:29 PM
krz6jdm
Feb 21, 2006 01:36 AM
se93
Oct 14, 2002 10:37 PM
teger
Apr 22, 2002 01:28 AM
