map sensor problem
Im having problems with my car and i think its either the map sensor or injectors. The car is idleing really low and then it dies out i can tell that its running really rich so i was wondering if there is anyway to test if the map sensor is bad. The map sensor is a Hondata 4 bar and the injectors are 880 cc the car is tuned on Hondata to.
the car dosnt stay running long enough for me to unplug the map sensor , if i would switch over to 1000cc injectors to check out if its a bad injector would that work ?
When did this problem start? did it run fine before with this map sensor and injectors? are you runing a resistor or a injector driver? more info please
