Map Sensor???
wrong. a 3 bar wont read past 28.x psi or 27.x psi i cant remember. but it inst 30. 3 bar = 14.7 x 2 - atmosphere(but there is a decimal inthere somewhere.) you always want to run a bigger map sensor than you will run pressure wise.
to accurately fuel the car and use the boost cut properly.
i could run a 3.5 bar, but im running 34 psi with plans of more with a turbo upgrade so i went with the 5 bar.
