Which Manifold/Turbo setup
Old May 2, 2010 | 06:45 AM
XxRoCkMaNxNEOxX's Avatar
Default Which Manifold/Turbo setup
I am in the process of rebuilding my motor. Below is what is consists of the block.
B18C1 sleeved AEBS 83mm
LS Crank
JE 10:1 Pistons
Manley Turbo Tuff rods.
My B16a2 head will be on this block. At the moment it will be stock head until I get funds to build it.
My current setup right now:
Stock B16a2
Blox Manifold
SC34 ar .48
550cc
255lph Walbaro FP
This will be a weekend car but I would like it to be a very fun car not too laggy but can make good power(good power band). I wanted to know the differences on the bottom mount divided/top mount divided. Also what turbo would be the best. I am looking for about 400 on the street(pump) and whatever c16 will give me later.
I do understand I need to change the fuel pump and go to higher injectors. I am mainly concerned with IM(Edelbrock or Skunk2)/Turbo Manifold/Turbocharger setup.
Just FYI: Future Head:
Skunk2 Pro1? or Tuner1 or tuner2
Super tech Valvetrain
Skunk2 Cam gears
Old May 2, 2010 | 06:53 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Which Manifold/Turbo setup
if 400 is your goal not too laggy, use a sk2 over the vic x. the vic x is great for top end. will hurt your low end.
400 is your goal only, get a decent waste gated log. a ram horn will be good, and you can grow into it.
i see you have a blox mani, that is a sk2 knock off right? that should do you fine. and an intake walbro will be fine for you.
Old May 2, 2010 | 07:26 AM
I prefer to be a little over 400 maybe 450. I know the vic x is better for top-end but would that hurt the cams I chose?
Blox manifold is the Turbo manifold not the IM.
Old May 2, 2010 | 04:16 PM
anyone. DD people with high hp, please chime in. thanks.
Old May 2, 2010 | 06:04 PM
95DC2GS-R's Avatar
my setup is being finished now and it will be fully capable of daily driving..
GE sleeved B16a 81.5
Eagle 1.8l stroker kit
9.3:1 c/r
turbo elements divided topmount
Precision 67/65 with billet wheel
Skunk2 pro 1's
and a victor X intake
will be running 500 for street and about 700 for race, car is being tuned on e85 with FIC 900's, walbro 255 and a Bosch 044 inline
Old May 2, 2010 | 07:22 PM
9.3:1 c/r
Skunk2 pro 1's
wow 6765 is big. Let me know if there is a big lag...I hear divided manifold matched with divided turbo is the way to go and is streetable even with a t4.
Old May 2, 2010 | 08:21 PM
95DC2GS-R's Avatar
There will definately be a difference in lag from my last setup (same motor on ramhorn and 18G) but on my tuner's motor which is a little bigger than mine with the same turbo kit made over 50lbs at only 5000rpm. I don't mind some lag, I don't want to be in boost on the street much any way, I'm really looking for part throttle cruising drivability so I'm still able to drive to events and the track
your setup is different so a 6765 will probably be over kill for you but I'm spinning the motor to 10k for a sick 5-10k rpm powerband
Old May 2, 2010 | 08:22 PM
Mr.Spec's Avatar
spoolin perf quick4AC if you're keepin AC
Old May 3, 2010 | 04:41 AM
I would love to keep A/C but it makes it very tight to work around with, but was looking at the Ramhorn A/C from Full-Race. What would I lose comparing the Ramhorn to a Divided Top Mount?
Old May 3, 2010 | 03:18 PM
bump
Old May 4, 2010 | 03:44 PM
any ideas guys. How about the turbos? Bulleye/Precision?
Old May 5, 2010 | 04:00 PM
Old May 5, 2010 | 08:53 PM
runsfromdacops's Avatar
if you want around 450-500 i would do the billit 6262 on a fr non ac ramhorn. cams i would say sk2 tunner 2s for im its the other way around the sk2 will make more topend but alot less everywhere esle in the power band. so i would go for the jg/vic x
Old May 6, 2010 | 09:35 AM
I was looking at the 6262 but I see different kinds. PTE/HP/SC whats the difference. Also is there a divided housing for the 6262. I was looking for a divided manifold to get the benefit of spool.
Old May 6, 2010 | 09:48 AM
TheShodan's Avatar
Moderator
for 450-500whp, the 6262 is ok, but its really big. you can have responsive setups that are a little smaller for that power need.
Every company has its pros and cons. what you need to do to get a more focused opinion is to be more descriptive about what it is you plan to do with the car as a basis (no E.Ts, please), how often you drive it (Daily, street, circuit or strip), and what your budget is. (And yes, EVERYONE has a budget). Honestly, for that power level, divided housing isn't necessary for response (see sig), but remember, the larger the wheels, the less responsive.
Old May 6, 2010 | 10:12 AM
This is car is a weekend driver but will definitely take it to the track. This will not be a race car but a fun car to drive. I would like to take it to the circuit if possible but not sure b/c the power would be too much. Maybe I could turn down the boost. Shodan what turbo would you recommend for my power level desire. 450 I would like on pump.
CRXherbie91
Dec 8, 2012 01:10 PM
seldon
Aug 21, 2009 09:54 PM
bubblevic
Jan 28, 2008 11:54 AM
ernald711
Feb 22, 2003 04:11 PM
SCHYBRID
Mar 12, 2002 03:59 PM
