Manifold Help
Old Oct 28, 2011 | 11:20 AM
Alen1293's Avatar
Default Manifold Help
I'm at the beginning stages of putting a turbo kit together for my b18 and I need some help. I have a stock motor other than DC headers and a gsr tranny. I don't want a high powered car, just a nice DD that has some power behind it. I think 180-200hp would be good. Now here are my questions:
Does anyone know about these manifolds? Good/Bad?:
http://www.go-autoworks-store.com/go...-manifold.html
http://www.go-autoworks-store.com/tumaco.html
http://www.go-autoworks-store.com/clloduaddon.html
Should I get an aftermarket head gasket, or a new Honda gasket?
What are some good turbos for low boost (5-8psi)?
What else would I need to do to the motor to run that low boost?
Thanks for all the help in advance.
Old Oct 28, 2011 | 11:43 AM
Fnix's Avatar
Default Re: Manifold Help
Those manifolds are good and the DP recirc is a must for a DD. For that low of power and PSI I would stick with the log manifold and invest the money elsewhere like the tune. OEM head gasket will be best and you really shouldnt need anything major done internally to the engine because your numbers are pretty low but I'll let some experts chime in.
Old Oct 28, 2011 | 01:51 PM
1158's Avatar
Take whatever your goal is and add 100 whp. lol
Seriously, you'll find it's addictive. As was posted above, you won't need to do anything to that motor just get a good tune. I had a 280-300 whp DD setup (GSR) that lasted 25K miles before I decided I needed more power. All of that was on stock internals.
Good luck.
Old Oct 28, 2011 | 02:14 PM
racebum's Avatar
Good luck.
cliffs: 280-300whp will actually go 25k+ miles on a stock b18c
Old Oct 28, 2011 | 02:23 PM
Alen1293's Avatar
I forgot to put that it was a b18b1, not a gsr lol. Thanks for the help though!
Old Oct 28, 2011 | 07:22 PM
TheShodan's Avatar
Moderator
same rules apply.
Old Oct 29, 2011 | 07:10 AM
Alen1293's Avatar
Originally Posted by TheShodan
same rules apply.
Alright, thanks. So what about those manifolds I posted links to.. have anyone had any experiences with them?
Old Oct 29, 2011 | 09:22 AM
racebum's Avatar
i'd go with this. also would use cast iron, not tubular. your hp goal is why and cast iron won't crack so easily like the tubulars do
Old Nov 1, 2011 | 03:40 AM
Alen1293's Avatar
Thanks for everyone's help. It's appreciated.
Old Nov 1, 2011 | 09:33 AM
TheShodan's Avatar
Moderator
Your first option is best
Get the entire kit, and don't try to piece it, as it comes with all of the equipment you need sans fuel pump, tuning management and injectors. Make sure you budget an uprated clutch first and break that in slowly. Good steel is available at a good price to you, so use it. DOn't worry about the cast stuff so much. That's a bit more touch and go.
jdmdohcek98
Jan 12, 2011 07:58 PM
roni_xxp
May 22, 2009 12:51 PM
mattwl
Honda Civic (2001 - 2005)
Oct 10, 2007 11:44 AM
GSRacer
Oct 15, 2001 08:09 AM
