making a b16 a 2.0L ??
Old Nov 23, 2005 | 12:54 PM
Griffin@Camtech's Avatar
Default making a b16 a 2.0L ??
I have a extra b16 block. is it possable to make a it a 2.0L. if its sleeved, running a LS Crank, LS rods, and LS pistons it should be a 2.0L I dont know if I am missing something like deck hight being different or something like that. anyone with anymore experence have any input?
thanks
Old Nov 23, 2005 | 01:07 PM
Adi Radoncic's Avatar
On Fire!
Default Re: making a b16 a 2.0L ?? (EG2nr)
The deck higth on a b16 is shorter than the b18c or the b18a/b.. If you wanna do this your gona need some ls rods, custom pistons and a bore over.
Old Nov 23, 2005 | 01:10 PM
Default Re: making a b16 a 2.0L ?? (Adi Radoncic)
cool. I was thinking that was what it was. custom pistons
Old Nov 23, 2005 | 03:48 PM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adi Radoncic &raquo;</TD></TR><TR><TD CLASS="quote">The deck higth on a b16 is shorter than the b18c or the b18a/b.. If you wanna do this your gona need some ls rods, custom pistons and a bore over.</TD></TR></TABLE>
If I were building a stroked B16 I would use B16 or B17 length rods, not LS length ones. I'll take a "worse" rod/stroke ratio with some supposed performance losses over having the piston pin completely through the oil ring with known oil control issues.
Old Nov 23, 2005 | 06:20 PM
Default Re: making a b16 a 2.0L ?? (tokes1320)
I feel you. scrap the b16 idea as cheap as b18b blocks are I will just pick one up. thanks guys
Old Nov 23, 2005 | 08:30 PM
seen4ever's Avatar
if you sleeve it with an ERL sleeve, you can get one of their Superdeck2 blocks with the LS crank, LS rods, LS pistons and have a 2.0L engine.
I have a ERL superdeck 2 with GSR crank, rods, pistons giving me 1.93L.
while deckplates got a bad name many moons ago, thier process of pressing thier deckplates into the block is pretty amazing. A few of us run thier blocks without any issues.
Old Nov 23, 2005 | 09:27 PM
Yea, but 1500 bucks for a block is alot when benson is less then a thousand. not knocking erl but thats a big difference. unless you know were to get the erl stuff cheaper
Old Nov 23, 2005 | 10:55 PM
DrVtec99's Avatar
yea earl promotes 700 hp benson blocks where erl blocks can handle more power. But its all about your goals and how u want to get to them.
Old Nov 24, 2005 | 06:24 AM
seen4ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2nr &raquo;</TD></TR><TR><TD CLASS="quote">Yea, but 1500 bucks for a block is alot when benson is less then a thousand. not knocking erl but thats a big difference. unless you know were to get the erl stuff cheaper</TD></TR></TABLE>
its the difference between getting 2.0L and goign 1.7L as well. I actually had a gsr block i sold to ERL and bought a b16 superdeck from them that one of their employees was selling. I ended up paying less than it would even cost to sleeve my block but got a new block with the deck plate. Plus since they warrenty everything they assemble, its nice having them 15 miles away from my house.
Old Nov 24, 2005 | 07:53 AM
MONTCO Si's Avatar
Check out my sig. ask for Josh and he will take care of you! They are one of the biggest ERL dealers on the east coast with amazing turn around time. But best of luck with either route you goin wheather it be ERL or Benson.
Old Nov 24, 2005 | 08:14 AM
Default Re: making a b16 a 2.0L ?? (DrVtec99)
thanks for the input guys. the goal is around 700whp (want to run 9s) I have talked to earl about the benson blocks and he says they will have no problems getting me there. but the erl blocks are looking like a good option as well
CTR_B
Nov 9, 2008 05:54 PM
CTR_B
Oct 17, 2008 04:19 PM
CO_CReX
Apr 26, 2006 11:03 PM
hOndafienD 04
Apr 6, 2005 08:42 PM
ls_vtec_b18a1
Oct 13, 2002 12:03 PM
