mahle pistons...h22
Old Aug 26, 2008 | 12:45 AM
92_boosted's Avatar
Default mahle pistons...h22
ive read and read what i could...in 07, there was a topic sayin issues were resolved...but a year later and im still looking for more on these...im new to h22 but searching and searching before jumping in...
the mahles claim no sleeving required...people say as long as the p2w clearance is in check...no issues...any new updates? id like to do mahles rather than doing resleeving if it only requires a hone and proper clearance, whats needed for a turbo build in the first place...
any info would be great...gaining all i can for this h22 swap
Old Aug 26, 2008 | 03:28 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: mahle pistons...h22 (92_boosted)
https://honda-tech.com/zerothread?id=1406865
this help?
Old Aug 26, 2008 | 11:27 AM
92_boosted's Avatar
found it quite helpful...im going to go with them...cause if your not spec'n out all the proper gaps and clearances...shouldnt even be building a turbo motor...ill take my chances with these pistons...ive heard more good then bad...and all bad are people sayin...trust me, there bad...no photos or proof that ive seen yet...thanx tho
Old Aug 26, 2008 | 12:12 PM
2point2's Avatar
Default Re: (92_boosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_boosted &raquo;</TD></TR><TR><TD CLASS="quote">found it quite helpful...im going to go with them...cause if your not spec'n out all the proper gaps and clearances...shouldnt even be building a turbo motor...ill take my chances with these pistons...ive heard more good then bad...and all bad are people sayin...trust me, there bad...no photos or proof that ive seen yet...thanx tho</TD></TR></TABLE>
I've researched these pistons quite a bit and it's getting harder and harder to find horror stories. People love to complain so No News is Good News.
Old Aug 27, 2008 | 08:28 AM
92_boosted's Avatar
thats what i am thinking...im gonna give them a shot personally...it takes a big set to claim you dont need sleeves to run them so ill put a set in and hope they dont lie
Old Aug 27, 2008 | 08:39 AM
purpleh22's Avatar
From what has been posted to date, important issues are piston to wall clearance and especially cylinder wall prep. Honing on these cylinders is a different procedure than typical honing. I believe Porche engine rebuilders have some experience with this type of cylinder liner.(FRM?) Mahle probably details the process pretty well in their instructions. Good luck. I hope to try their 'Gold' series pistons myself, in the future.
Old Aug 27, 2008 | 11:14 AM
2point2's Avatar
Default Re: (purpleh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 &raquo;</TD></TR><TR><TD CLASS="quote">Honing on these cylinders is a different procedure than typical honing. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=405266
http://members.shaw.ca/FourthG...).pdf
Old Aug 27, 2008 | 11:48 AM
92_boosted's Avatar
im calling lots of shops to get the best one for the job...i dont know of any porshe shops in the colorado area that wont charge an arm and a leg...i am just lookin for an experienced shop that someone has gone to and had good out comes in colorado...shop here is complete ****...unless the big block shop...but its not a v8
Old Aug 27, 2008 | 02:27 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_boosted &raquo;</TD></TR><TR><TD CLASS="quote">im calling lots of shops to get the best one for the job...</TD></TR></TABLE>
Have you inspected the block yet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">FRM honing is not required unless the cylinder has deep vertical scratches that run the length of the bore. </TD></TR></TABLE>
Old Aug 27, 2008 | 05:33 PM
h-duced's Avatar
I got Mahles in this Hopefully it will see a dyno in about 2 weeks
[IMG][/IMG]
Old Aug 28, 2008 | 10:28 AM
92_boosted's Avatar
the block is still fully assembled with the stock components...was running clean across the board when pulled...that motor looks clean man...good luck
Old Aug 28, 2008 | 05:39 PM
h-duced's Avatar
thanks man, its so clean right now i could eat off of it lol
Old Aug 30, 2008 | 10:52 AM
92_boosted's Avatar
Default Re: (h-duced)
definately looks like it...what parts you runnin in the head?
Old Aug 31, 2008 | 03:24 PM
h-duced's Avatar
super-tech valves springs retainers and ported
Old Sep 5, 2008 | 11:59 AM
92_boosted's Avatar
what goal you shootin for?
Old Sep 5, 2008 | 01:13 PM
extralargenog's Avatar
Default Re: mahle pistons...h22 (h-duced)
supertech valves Their springs and retainers ROCK SOLID though
Old Sep 5, 2008 | 06:38 PM
h-duced's Avatar
Default Re: mahle pistons...h22 (extralargenog)
I never had any problems with them they have treated me good so far
huge230
Aug 11, 2022 07:54 AM
nosmark21
Apr 13, 2015 07:44 PM
halcyon
May 13, 2004 01:58 PM
tranceguy
Oct 5, 2002 10:44 AM
makaveli284
Sep 20, 2002 08:50 AM
