Retorqueing head studs necessary?
Old Dec 21, 2008 | 06:06 PM
scspeed's Avatar
Default Retorqueing head studs necessary?
Is it necessary to retorque your ARP head studs after so many miles? i bought mine new. Torqued them down. But read that after 500-1000 miles after they should be retorqued..What do you think???
Old Dec 21, 2008 | 06:18 PM
rmcdaniels's Avatar
Default Re: Retorqueing head studs necessary?
I always do mine after a few heat cycles, and the directions from ARP say to do it, but lots of people don't and are fine. I figure it only takes a few minutes and can't hurt anything.
Old Dec 21, 2008 | 06:31 PM
Boner_Ben's Avatar
I have never re-torqued mine and have also never had any headgasket failures.
Old Dec 21, 2008 | 06:32 PM
95dc2teg's Avatar
i think it would be kind of a pain in the *** to do since the cams and timing belt have to come off on vtec b-series motors. i have never done that and have had no problems thus far.
Old Dec 21, 2008 | 06:38 PM
BiggieBert's Avatar
Loved
Community Favorite
I havn't retorqued my arp's and i've been boostin for about 1500 miles with no probs.
Old Dec 21, 2008 | 06:56 PM
Antilag's Avatar
What i like to do is... After i do the final torque to the specs i want. I let it set for about 15-30 minutes. Then i start with the tightening sequence and back off a quarter turn and retorque them. Never had an issue with mine. But i guess mine is overkill, but i like to just make sure.
But if your not having issues with pressure in the radiator, or the head lifting under pressure, i would leave it alone. You should be fine.
What are your power goals?
Old Dec 22, 2008 | 04:27 PM
scspeed's Avatar
ok thanks guys...idk i think im just going to leave it alone...especially if arp says its fine. The bottom end is built with je pistons eagle rods and has a triple layered head gasket...Head is stock. I made 400whp and drove in for about half the summer like that with no issues...I just like to be very cautious with little things like that which is why over winter i was going to retorque.
Old Dec 22, 2008 | 04:32 PM
BiggieBert's Avatar
Loved
Community Favorite
I bet if you got in there to retorque them, your wrench would click before they even turn.
Old Dec 22, 2008 | 05:13 PM
Antilag's Avatar
Yeah i would leave it alone, you should be fine! If you were gonna have any problems or issues, you would of had them a long time ago.
Old Dec 23, 2008 | 05:51 AM
mangina's Avatar
I retorqued mine after 1000 miles and found that 3 of them were not at 80
so I would recomend it.
Old Dec 23, 2008 | 08:28 AM
TurboK's Avatar
cant hurt to retorque them.
DreTec
Jun 14, 2010 07:19 AM
scspeed
12
Dec 22, 2008 08:23 PM
boosh
Sep 17, 2007 09:12 AM
andrewasf77
Apr 11, 2003 12:43 AM
hatchy
Mar 9, 2003 01:57 PM
