lsvtec dyno numbers
Old Mar 4, 2005 | 08:20 PM
deeweezy187's Avatar
Default lsvtec dyno numbers
what kind of power are you lsvtec guys making and would i be able to make 400+whp with a lsvtec would ya'll be able to post dyno graphs
Old Mar 4, 2005 | 08:33 PM
B20TDC2's Avatar
Default Re: lsvtec dyno numbers (deeweezy187)
its not ls/vtec but b20 426hp & 322trq @ 18.5 lbs
hope it helps & those numbers are on pump gas, click to enlarge it
Old Mar 4, 2005 | 08:42 PM
Default Re: lsvtec dyno numbers (B20TDC2)
i heard that the b20 has problems reving or somthing like that is that true?
Old Mar 4, 2005 | 08:58 PM
Chrome Pipes's Avatar
Stock B18B block / Stock B16a head:
LS/VTEC All the way, never had a problem - rev it out to 8k and thats it.
Old Mar 4, 2005 | 09:35 PM
turboEGhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweezy187 &raquo;</TD></TR><TR><TD CLASS="quote">i heard that the b20 has problems reving or somthing like that is that true? </TD></TR></TABLE>
lol, yes
And VTEC doesn't work with turbos, and the LS trans is awesome for boost, and you don't want big cams because overlap sucks!
Old Mar 4, 2005 | 10:23 PM
mrDFWmechanic's Avatar
Default Re: lsvtec dyno numbers (Chrome Pipes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chrome Pipes &raquo;</TD></TR><TR><TD CLASS="quote">Stock B18B block / Stock B16a head:
LS/VTEC All the way, never had a problem - rev it out to 8k and thats it.</TD></TR></TABLE>
wow 355hp with all stock motor and a turbo kit ... thas not bad at all. what kinda kit is it ?
Old Mar 5, 2005 | 02:28 AM
blackANESE's Avatar
Default Re: lsvtec dyno numbers (turboEGhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch &raquo;</TD></TR><TR><TD CLASS="quote">lol, yes
And VTEC doesn't work with turbos, and the LS trans is awesome for boost, and you don't want big cams because overlap sucks!</TD></TR></TABLE>
Don't forget Eagle rods are the worst thing on the planet
Old Mar 5, 2005 | 03:45 AM
hondaguyef's Avatar
lol, yes
And VTEC doesn't work with turbos, and the LS trans is awesome for boost, and you don't want big cams because overlap sucks!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackANESE &raquo;</TD></TR><TR><TD CLASS="quote">
Don't forget Eagle rods are the worst thing on the planet</TD></TR></TABLE>
ROFL
Chrome Pipes Gets for the killer numbers though.
Phil
Old Mar 5, 2005 | 05:09 AM
LSVtechnologytur...'s Avatar
Default Re: lsvtec dyno numbers (hondaguyef)
Chrome Pipes - what turbo was that?
sweet #'s
Old Mar 5, 2005 | 07:04 AM
System-7's Avatar
Default Re: lsvtec dyno numbers (blackANESE)
using eagle rods for two years now, no problem. they aint' carillo rods though.
Old Mar 5, 2005 | 08:00 AM
Default Re: lsvtec dyno numbers (iROCKtheSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">
wow 355hp with all stock motor and a turbo kit ... thas not bad at all. what kinda kit is it ? </TD></TR></TABLE>
Its a bolt-on DRAG III kit with a TO4E 60 trim.
Brief rundown of setup:
Stock Internal B16a head
Stock Internal B18b block
NO Blockguard
InlinePro 2mm headgasket
ARP headstuds
RC 440's, Cartech FMU , V-AFC, Holly 255 lph intank
MSD ignition, cap, external coil, wires, 2 step
Thats pretty much it.
If 400 whp is what your are looking for, its really not going to be a problem, however I personally wouldnt go that far without - piston/rods/some sort of engine management.
For me personally.....375 whp is max on stock internals. Thats as far as I'm willing to take it...
Old Mar 5, 2005 | 08:18 AM
gsrboost's Avatar
Chrome Pipes at what psi did you make 356whp? You have a pretty close setup to mine but i have a gsr and im looking to be pushing around 350 to the wheels. Also was your car stripped to run that 11.5? That is pretty damn impressive!
Old Mar 5, 2005 | 08:46 AM
Default Re: lsvtec dyno numbers (gsrsp33d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrsp33d &raquo;</TD></TR><TR><TD CLASS="quote">Chrome Pipes at what psi did you make 356whp? You have a pretty close setup to mine but i have a gsr and im looking to be pushing around 350 to the wheels. Also was your car stripped to run that 11.5? That is pretty damn impressive!</TD></TR></TABLE>
The engine made 356 whp at like 16-17 psi using C16. I only run like 12 psi on the street on pump. The car weighs 2550 with me in it. It's not stripped, I mean there's no back seat, but its all carpeted and all the panels are in place. There's no power steering, no a/c, Sparco wheel, passenger airbag tray.
Good luck with your setup, believe me 350 whp on a stock motor isn't a big deal. However, the car isn't my daily driver and I'm easy on it most of the time. Drag racing is another story.....
Old Mar 5, 2005 | 09:20 AM
MidShipCivic's Avatar
And VTEC doesn't work with turbos.</TD></TR></TABLE>
This is a new one.
Who told you that
That Mcdonalds vtec edumacation.
Old Mar 5, 2005 | 10:18 AM
speeddave's Avatar
Default Re: lsvtec dyno numbers (MidShipCivic)
hey chrome pipes, what is the spool like with the to4e 60trim? is it the .63a/r exh?
Old Mar 5, 2005 | 10:57 AM
f22b2tdave's Avatar
its called sarcasm midship.....he was answering a question on if the b20's have problems revving....im pretty sure any b20 that cant rev well, might have a valvetrain issue
Old Mar 5, 2005 | 10:59 AM
Default Re: lsvtec dyno numbers (f22b2tdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2tdave &raquo;</TD></TR><TR><TD CLASS="quote">its called sarcasm midship.....he was answering a question on if the b20's have problems revving....im pretty sure any b20 that cant rev well, might have a valvetrain issue </TD></TR></TABLE>
You know I was playing along right?
Old Mar 5, 2005 | 11:12 AM
*Boostwerks*'s Avatar
Umm...a lil lean there don't ya think?
Old Mar 5, 2005 | 11:45 AM
Dsm634's Avatar
LOUD NOISES
Nice car
Old Mar 5, 2005 | 12:48 PM
Default Re: lsvtec dyno numbers (speeddave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave &raquo;</TD></TR><TR><TD CLASS="quote">hey chrome pipes, what is the spool like with the to4e 60trim? is it the .63a/r exh?</TD></TR></TABLE>
Yes, it's the .63 a/r. Spool is not too bad, just gotta be in the right gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
Umm...a lil lean there don't ya think? </TD></TR></TABLE>
Ya, I know. I richened it up a little since then.
Old Mar 5, 2005 | 02:39 PM
speeddave's Avatar
rough guestimate of full spool rpm?? thanks
Old Mar 5, 2005 | 06:05 PM
686_ef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
That Mcdonalds vtec edumacation.</TD></TR></TABLE>
lol....
vtec is the ****!!!
del_orson
Oct 1, 2006 03:41 PM
Slow_import
Oct 24, 2005 10:56 PM
Vintech
Mar 7, 2004 12:58 PM
aandDavidsaid
24
Jan 26, 2004 01:30 PM
kHoA DoGG
Oct 10, 2002 06:58 PM
