LSV Turbo is this a good setup
Old Nov 2, 2006 | 02:59 PM
Spec R_GSR's Avatar
Default LSV Turbo is this a good setup
stock b18b block
nuformz block guard
eagle girdle
eagle rods
str pistons 10.5.1 cr
port and polished b16 head w/ 3 stage valve job
skunk 2 stage 1 cams
jun cam gears
ITR Intake mani
t3/t4 turbo w/ 3" DP
38mm tial watsegate
Greddy Super S BOV
3" exhaust
GSR gearbox w/viscous diff
C&R aluminum Radiator
MSD Blaster 2 Coil
ECU running Crome
Oil Cooler
Front mount intercooler with fal fan installed
Walbro 255 intank fuel pump
Vafc Neo thinking of upgrading to emange U
this is all i have so far am i forgetting anything.......any recommendations
Modified by Spec R_GSR at 4:19 PM 11/2/2006
Old Nov 2, 2006 | 03:25 PM
bigdgsr's Avatar
Default Re: LSV Turbo is this a good setup (Spec R_GSR)
Looks like a good start, but you still need to do some more research. What are your power goals with the car? Is it DD? Going to the track with it? You aren't going to run Crome and E-manage together. Definitely go with Crome Pro. Way superior to what E-manage can do and it will be a lot cheaper. 10.5:1 Compression is doable but the tune better be dead on. Also you aren't going to be mounting a fan on your IC. The fan goes on your radiator. Oil cooler probably won't be necessary.
Old Nov 2, 2006 | 03:34 PM
Spec R_GSR's Avatar
Default Re: LSV Turbo is this a good setup (bigdgsr)
well interms of power goals i was thinking 350-450hp anywhere between that ill be ok...what cr would you recommend....for management its either going to be crome or emanage but i ll just still to the crome ill probly do alittle drag racing but it should mostly be a DD....i see yopur point with the fan on the IC though i think it could work but i wouyld probly use at the track only just for allittle more cooling cause that fan would have to run all the time to be any good........
Old Nov 2, 2006 | 03:47 PM
bigdgsr's Avatar
350-400whp is doable. Majority of people run anywhere from 9:1 to 9.8:1 compression. You didn't state what pistons or manifold you are going to go with. Also what size turbo you deciding on? Do a search to see what other users with LS-VTEC turbos are putting down and what parts they used. The fan on the IC isn't really going to do anything. If you wanna cool the IC, look into the nitrous IC.
Old Nov 2, 2006 | 04:01 PM
Spec R_GSR's Avatar
thanks ill do a little more research and get back to you.........for the turbo i know immo go with some t3/t4 setup not sure abot the .ar just yet.str piston i metioned that any recommendation on the manifold.........?
Old Nov 2, 2006 | 04:11 PM
bigdgsr's Avatar
Depends on a lot of things. Do you plan on keeping PS and AC? I personally made 400whp while keeping AC and PS. I use a SFP log manifold. I personally run Wiseco pistons. I would go with Wiseco or CP Pistons. Keep doing research so you do things right the first time and find a good tuner.
Old Nov 2, 2006 | 04:37 PM
urbansi's Avatar
Ditch the AFC hack and get some large injectors, as for that blockguard it really isnt worth the trouble, JMO...
Hyper16-Johnny
Mar 29, 2008 02:06 PM
s2kkid
Jun 10, 2006 12:30 PM
Jake92eg
Apr 26, 2006 07:55 PM
b18b25psi
Mar 3, 2002 02:11 PM
