LSV Turbo Build Question.
Old Jul 26, 2014 | 05:40 PM
MainManKeegan's Avatar
Default LSV Turbo Build Question.
Hello hondatech, new to the turbo scene. I have a question about a build i have sitting around thinking about slapping it together and see what the results are.
I have a stock LS bottom(b1) with a built b16 head.
b16 Built Head:
Full supertech head, with SK2 Pro1's.
Victor X ported to match a 70MM TB.
RC 1000cc Injectors.
B18B Bottom:
All Stock but a Block Guard.
(Simple Ebay turbo kit, t3/t4) (RamHorn Manifold if that helps)
Also a 3' Exhaust
i obviously have new Headstuds(arp with a honda HG).
Have a hondata s300 that will be tuned on e85. Im looking to find out whats the safest amount of boost i should run on this setup. I was thinking 15lbs would be good but then again im not sure. Also looking to see what type of power i should be making. I seen stock LSV's make 300whp. So for me is asking 400whp too much?
Had the pro1's laying around and heard they make great power when boosting (quote from Jeff Evans tuning). Just looking for some feed back guys thanks!
P.S.
If it comes to it i will rebuild the bottom just looking to see what i can make do with what i got, lol. Thanks again!
Old Jul 26, 2014 | 07:00 PM
phaphon's Avatar
Default Re: LSV Turbo Build Question.
Bad Idea go read the FAQ .
Old Jul 26, 2014 | 07:04 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
No block guard and eBay kit.
Old Jul 26, 2014 | 08:53 PM
hardcore97's Avatar
dont reference psi for what a motor can handle. 15 psi on a t28 would be fine whereas 15 psi from a gt40 would be too much for the motor to handle. set a hp goal and build accordingly.
Old Jul 27, 2014 | 04:58 AM
I only ask cause i know someone who ran a fully built head w/tuner2's and a 75 shot on a legit stock block. No rod bolts no nothing
Old Jul 27, 2014 | 05:00 AM
Thanks for the input, i have this **** laying around i just want to see what i can get out of what i have laying around. Thats it
Old Jul 27, 2014 | 05:07 AM
phaphon's Avatar
I'm just telling you to read the faqs to help you out. Like they said get quality parts
Old Jul 27, 2014 | 06:07 AM
wantboost's Avatar
Who is Mr Robot?
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Read the FAQs linked above
Read them again
Think about what you read
Grab a beer and re-read the stuff you don't understand.
you won't make 400whp reliably on stock internals even on e85... Add in the very reliable eBay kit (pure sarcasm FYI) and then you'll be hard pressed to have the car make it off the dyno under its own power.
Cheap
Fast
Reliable
pick 2 because that's what your build will be.
jdmnic91
Aug 9, 2014 06:22 AM
thatHEMIguy
May 3, 2010 09:24 AM
2ndchirp
Mar 14, 2009 05:38 AM
Navy_CRX
Feb 21, 2009 01:45 AM
nateg
Feb 20, 2007 09:03 PM
