LS/VTEC VS. B20/VTEC for FI...
Subscribe
Aug 9, 2006 | 07:40 AM
I dont know anything about the B20 vtecs. I have a buddy who is making decent power with his semi-built ls/vtec at 13 psi. I was boosting my old b16, but I want something more. and after seeing, riding, and driving his setup, I want to do an LSvtec build. But I started thinking that maybe the b20vtec would be a better idea.
Block will be sleeved, forged pistons, rods, everything. No stone left unturned on the block or head. It will be built to make lots of power. Aiming for at least 500 whp. This will be dropping into my 91 crx and mated to a 99-00 Si transmission with LSD.
What would be a safe rev limit for the b20 with the longer stroke? I'd like to take it out to 9 grand.
Anyone got recomendations on either setup over the other? Thanks!
Reply 0
Aug 9, 2006 | 07:47 AM
Re: LS/VTEC VS. B20/VTEC for FI... (B16CRXT)
talked on aim
but i do know someone with endyn roller wave pistons in a b20/vtec with darton open deck sleeves that held pretty nice...it was an all motor set up...but he is now doing a turbo build with the same block...i guess if you're going to do all out build and keep a stock crank...it's all about which one is better and makes more tq i would guess
Reply 0
Aug 9, 2006 | 08:01 AM
Re: LS/VTEC VS. B20/VTEC for FI... (TehMan)
crank will be knife edged and balanced. I'm thinking the setups would be very similar, but the b20 would make more tq and spool the turbo up a bit faster.
Reply 0
Aug 9, 2006 | 08:09 AM
2.0 ftw!
Reply 0
Aug 9, 2006 | 08:14 AM
The B20 and LS have the same stroke, the only difference is the bore size and the B20 crank weighs more(I am pretty sure but not 100% sure). I would say go with the sleeved B20 block and a LS crank.
Reply 0
Aug 9, 2006 | 08:59 AM
Re: LS/VTEC VS. B20/VTEC for FI... (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote"> sleeved B20 block and a LS crank.</TD></TR></TABLE>
Reply 0
Aug 9, 2006 | 09:20 AM
Thanks for that idea and the info. Anyone got fact on teh different weight of the cranks? I'm pretty sure it will be a b20 block at this point...
Reply 0
Aug 9, 2006 | 09:44 AM
Either block will be good to go.
Since you are sleeving and building, it doesnt really matter.
If all you are looking for is the stroke, youll have your 89m, and then from there, you can get daring if you would like and get a Eagle or Crower crank.
I will talk to you more in person about it. I will also send some help your way for this thread.
I hate to say it, but search a little on it, see what people are doing and what their goals were compared to yours.
Also, and i know you have faith in your tuner, but with every setup, power and reliability will vary via the tuner...
Reply 0
Aug 9, 2006 | 09:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for that idea and the info. Anyone got fact on teh different weight of the cranks? I'm pretty sure it will be a b20 block at this point...</TD></TR></TABLE>
i'd go with whatever block you can get cheaper, your going with sleeves right? all you need to do to make the ls a 2.0 is put in 84mm sleeves. That is unless your hung on getting the b20 written on the block.
Reply 0
Aug 9, 2006 | 09:48 AM
Re: LS/VTEC VS. B20/VTEC for FI... (Stunna BEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stunna BEN &raquo;</TD></TR><TR><TD CLASS="quote">
Also, and i know you have faith in your tuner, but with every setup, power and reliability will vary via the tuner...</TD></TR></TABLE>
That's why I like J. Davis. He looks at your goals and how you will use/drive that car and tunes accordinly. You tell him you need safe he goes safe, you want hp he gives you hp. He won't blow up your car just so he can post up impressive numbers.
Reply 0
Aug 9, 2006 | 09:54 AM
Re: LS/VTEC VS. B20/VTEC for FI... (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">That's why I like J. Davis. He looks at your goals and how you will use/drive that car and tunes accordinly. You tell him you need safe he goes safe, you want hp he gives you hp. He won't blow up your car just so he can post up impressive numbers.</TD></TR></TABLE>
Reply 0
Aug 9, 2006 | 10:02 AM
exactly. I'm gonna talk to him about it and see what his ideas are on it...
Reply 0
Aug 9, 2006 | 10:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">exactly. I'm gonna talk to him about it and see what his ideas are on it...</TD></TR></TABLE>
Travasses set up without the stiff valve train dbl springs that keep flattening cam lobes.
Reply 0
Aug 9, 2006 | 11:03 AM
if jd tunes it for you...this asian guy is gonna be mad
Reply 0
Aug 9, 2006 | 11:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMan &raquo;</TD></TR><TR><TD CLASS="quote">
if jd tunes it for you...this asian guy is gonna be mad</TD></TR></TABLE>
hahahaha I guess he told you he was booked?
Reply 0
Aug 9, 2006 | 11:21 AM
no he just wouldn't get back in touch with me like he said...but he said he would tune it...i even offered to pay him double
Reply 0
Aug 9, 2006 | 03:37 PM
89x84..... sounds like my setup. except all mota for me!
Reply 0
Aug 9, 2006 | 03:45 PM
ls/vtec
Reply 0
Aug 9, 2006 | 04:40 PM
Re: (cuin9sec)
Talked with Ben some and determined there is no difference that will reall ymean anything once the motor is boosted btwn the cranks. And once, it is sleeved, the larger bore wont mean jack. LS/Vtec FTW!
Now to the next question...closed deck sleeves or get the block super decked??
Reply 0
Aug 9, 2006 | 04:46 PM
Re: (B16CRXT)
I will require this block to be able to cool and not overheat. I'd like to be able to drive it around and not have a strip ***** on my hands.
Reply 0
Aug 9, 2006 | 05:31 PM
Re: (B16CRXT)
i'd just get closed deck sleeves...darton charges 900 dollars for the sleeves and to install MID sleeves in ur block...u send the block with 900 dollars and its done
Reply 0
Subscribe
