LS-Vtec turbo ripper VIDEO
Re: LS-Vtec turbo ripper VIDEO
sounds mean but sounds like all motor. and not to knock your setup but i dont see how thats 420whp. Not to be the one to say anything but i can eat through the gears much quicker at 350whp in my gsr. was that on low boost?
It does really sound like a NA car tho. I can't hear the turbo or gate or nada.
sounded more like a turbo car in this video..
http://www.youtube.com/watch?v=KX5nM...e=channel_page
JE pistons eagle rods
Stock sleeves LS block 81.5
Skunck 2 spring and retainers Blox B's cams (thats why its sounds like NA)
VictorX and 68mm TB
B16 head stock ports.
B16 tranny oem LSD
Competicion Stage 5 clutch
GT37r BB turbo and 44mm wategate
3" exhaust
Precision 880cc injectors
no boost controller
Tuned on Crome...
Nothing crazy simple setup
VictorX and 68mm TB
B16 tranny oem LSD
3" exhaust
no boost controller
Tuned on Crome...
tq seems a little low. but i bet its just conservative i suppose. throw some more timing in that bitch.
also it doesnt seem like its full tilt in the first video. especially as light of a car it is. 420 should pull harder. it seems like it pulls about just as quick as my stock b16 on 11 lbs which is around 340 wheel.
anywho, cool setup. pump gas im guessing?
VictorX and 68mm TB
B16 tranny oem LSD
3" exhaust
no boost controller
Tuned on Crome...
VictorX and 68mm TB
B16 tranny oem LSD
3" exhaust
no boost controller
Tuned on Crome...
Ripper video is the must.
Yes pump gas, the problem is it only makes bigger power after 8k to 9k rpm. but I'll boost it up later will see what I get.
