LS Vtec turbo rebuild! Lots of pics -*Now parting out/selling*
Old 06-09-2014, 11:41 PM
  #401
m4xwellmurd3r's Avatar
Ouch, thats why I have two used pumps that should be fine sitting in the corner, and forked out the cash for a new oem obd2 pump.
Running a car with a used heart is like throwing tge engine together without checking any bearing clearances
m4xwellmurd3r is offline
Old 06-10-2014, 07:50 AM
  #402
turbohatch96y7's Avatar
Was this a rebuild? Or was the motor stock? I can't remember
There's no reason you should lose oil pressure if you left the bottom end untouched.
Sadly if you already have low oil pressure at 4000 rpm I'm afraid the damage is done.
turbohatch96y7 is offline
Old 06-10-2014, 07:54 AM
  #403
Who is Mr Robot?
wantboost's Avatar
Default re: LS Vtec turbo rebuild! Lots of pics -*Now parting out/selling*
^yup
wantboost is offline
Old 06-10-2014, 07:58 AM
  #404
Slacker93eg's Avatar
Bottom end was rebuilt by a reputable machine shop, I put roughly 1000-1500 miles on it? No problems. When I drove the car in the lowest the oil pressure was at idle was 12-20psi. My guess is something is clogging the oil pickup.
Slacker93eg is offline
Old 06-10-2014, 08:01 AM
  #405
Who is Mr Robot?
wantboost's Avatar
if pressure dropped to 5psi regardless of engine speed you've damaged the motor.... period
Old 06-10-2014, 11:17 AM
  #406
Just went in and checked it out, car is idling at 40psi cold and once it's warmed up it drops to around 12psi. I'm starting to think it's the type of oil I used. I'm still going to get the car home and replace the oil pump and check it over. No knocking or noises, it's partially tuned and now running on E85. Car made 220whp at 6k and then vtec dropped off on 7psi. He says once I get the oil problem fixed he's expecting to make mid to upper 400.
Thursday I'm picking the car up and taking it home.
Old 06-10-2014, 11:18 AM
  #407
ballistic1350's Avatar
What kind of oil were you using?
ballistic1350 is offline
Old 06-10-2014, 11:23 AM
  #408
Quaker State synthetic 10w30 with that extra zinc additive stuff in it.
Old 06-10-2014, 11:28 AM
  #409
and thats what you used for break in?
Old 06-10-2014, 11:30 AM
  #410
No, the oil has been changed like 4 times since I started breaking it in.
Old 07-29-2014, 06:37 PM
  #411
ctunez's Avatar
Update? Pretty anxious to continue reading. This Thread is keeping me motivated in my build.
ctunez is offline
Old 07-30-2014, 07:09 PM
  #412
Sorry it's been a while, got pretty frustrated and actually ended up moving into a new house. Today I tried the other oil restrictor I had laying around to see if it changed the oil pressure problem. Didn't really do anything. I'm still baffled as to what could have caused such a drop in pressure after simply installing roughly 3 feet of -3 oil line and an oil return. There was literally NO oil problem when the turbo stuff was off.
Old 07-31-2014, 07:07 AM
  #413
Moderator
TheShodan's Avatar
An oil restrictor to the turbocharger only regulates oil flow to the turbo and has nothing to do with rest of the engine. If anything, using that larger fitting could cause an oil backup issue that could push oil past the oil sealing ring on the turbine shaft. Going back to the other .060" that you originally had is best.
It is more than likely time to check bearings, oil pump, pick up, etc.
TheShodan is offline
Old 09-25-2014, 04:14 AM
  #414
rpehrson86's Avatar
slacker, i'm a huge honda buff. i just joined here figured i would give some insight. i wouldn't use anything but oem parts for a honda, except aftermarket rods, pitons, etc. i have many friends running the oem crank with high hp levels, as it is a forged piece. i recommend injector dynamics for injectors, tial for wg and bov all day. intercooler (once you go higher hp), i would go with a treadstone performance one. don't use rtv on any rubber gaskets, they will leak. i learned that trick from my grandfather (he's been working on airplanes and cars for 55 years). the top hole above the throttle body is for evap can, as is the other one behind the intake manifold. not needed if deleted. but that hose behind the intake manifold i would use for the BOV and t into it for the boost gauge. align honing is a must for arp main studs, otherwise you can spin bearings, and of course if you boost, you do not want to turn a crank (turning means to have them polish it down and use over sized bearings). i'm not critiquing your build one bit but, it's awesome how far it's come in the last two years, i've read all of the thread. hey if you ever have any questions, please e-mail me. i don't know everything, but i have picked the brains of many many professional racers and builders so i do know a lot. nice build! i'm glad to see people still do some things on their own!
rpehrson86 is offline
Old 09-25-2014, 04:22 AM
  #415
rpehrson86's Avatar
also, be careful with that manifold where the wg hangs on like that because mine has dropped off a few too many time before myself lol. i did use a washer that had a grippy feel to it, not a lock washer though, and the new one never came off. as for the manifold, i would replace it with a cheap blox cast iron one, they will not crack like those steel ones will, they always crack in the middle part because of over welding and burning too much of the metal. anyhow, yeah like i said email me if you have ANY questions at all!
Old 09-25-2014, 10:16 AM
  #416
Lol
Old 09-25-2014, 02:24 PM
  #417
Oh my what words of wisdom...
Old 09-29-2014, 03:44 AM
  #418
minimarine09's Avatar
Lol, this guy...
minimarine09 is offline
Old 05-15-2015, 09:36 AM
  #419
Honda_Caveman's Avatar
Its been like 8 months but I just read through the build. It was nice seeing everything come together. Did you ever figure out the oil issue?
Honda_Caveman is offline
Old 05-18-2015, 08:06 AM
  #420
GrantMC2's Avatar
What happened? Spent all afternoon reading this!!
GrantMC2 is offline
Old 05-22-2015, 06:45 AM
  #421
JDMarv's Avatar
just read the whole thing this morning, any updates slacker? :/
JDMarv is offline
Old 01-07-2017, 03:53 AM
  #422
RoseTheTeg's Avatar
This thread makes me cringe not knowing what happened in the end... sorry for the old bump guys but; OP where are you?! Lol
RoseTheTeg is offline
Old 01-10-2017, 04:30 AM
  #423
I ended up moving right after this happened, car is sitting int he garage currently. Hasn't been touched since this all happened. I constantly teeter on the thought of selling or fixing it lol. I don't have the disposable income I had when building this car. I really want to fix it, but part of me says I don't need a race car I need the money lol.
Old 01-10-2017, 08:30 AM
  #424
JRCivic1's Avatar
Everybody needs a race car slacker... or at least something that makes them smile when it works right. The obstacles that we must overcome make it that much sweeter. Giving up is easy... see it through and smile again !!!
JRCivic1 is offline
Old 01-10-2017, 09:15 PM
  #425
RoseTheTeg's Avatar
Back in the day my dad used to have a 10sec civic that he dumped a lot of money into. Him and my uncle always talk about "I can't believe we spent all that money just to go fast".. it hits me every time I purchase another part or even think about putting in another dollar. But once you fall in love with speed you don't go back. My dad has since owned s2000's, an e46 m3, and has just recently purchased a Dodge Viper... as much as how unimportant it may feel at times everyone is on this forum for a reason. We all need a racecar, it's the little things that count. Just take care of your bills first, the racecar can always wait. I'm glad you still have the car.. and I hope you get the motivation to bring this thing back one day, even if it takes years! 👍🏻
Quick Reply: LS Vtec turbo rebuild! Lots of pics -*Now parting out/selling*
