ls vtec turbo feed line
Old Nov 13, 2001 | 10:36 PM
ILOVEGIRLS's Avatar
Default ls vtec turbo feed line
where do i put the oil feed line if my sender already is tapped for the ls vtec setup?
Old Nov 13, 2001 | 10:50 PM
paulzy's Avatar
Default Re: ls vtec turbo feed line (ILOVEGIRLS)
you can add another fitting. what somepeople have done is use the hole under the distributor. It's plugged from the factory. You will need AN fittings...
Old Nov 14, 2001 | 07:51 AM
chri5's Avatar
Default Re: ls vtec turbo feed line (Slow_ass_4dr)
Here is where I tapped my oil feed. I have a shorter line now, but it is still basically the same.
Old Nov 14, 2001 | 02:35 PM
lswithvtec's Avatar
New User
Default Re: ls vtec turbo feed line (Chris_Turbo)
i tho by doing this it will not give enought oil to activie vtec? how long have you been running it from there?
Old Nov 14, 2001 | 04:15 PM
ILOVEGIRLS's Avatar
Default Re: ls vtec turbo feed line (lswithvtec)
yeh..wsup with the pressure..
Old Nov 14, 2001 | 04:21 PM
chri5's Avatar
My VTEC works with it there. I've had it there for abouta month or so now, and no ill signs as of yet.
Old Nov 14, 2001 | 04:44 PM
Adi Radoncic's Avatar
On Fire!
Chris, Can you please tell us how you did the install what kind of parts are needed and such, I'm really interested in this because I have a Oil pressure gauge hooked up to my oil sending unit.........
Thanks in advance....
Old Nov 17, 2001 | 11:24 PM
ILOVEGIRLS's Avatar
Default Re: ls vtec turbo feed line (newgsr)
yeh..i wanna check this out a bit more.
madcrx69
Apr 17, 2010 05:31 AM
m2theizzy
Feb 14, 2009 05:51 PM
Superdragr45
Jul 26, 2005 06:02 PM
lswithvtec
Nov 27, 2001 11:06 AM
