LS-VTEC Turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">on a stock ls crank?</TD></TR></TABLE>
Yep
Yep
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 »</TD></TR><TR><TD CLASS="quote"> IMO, i'm not reving over 7,800.</TD></TR></TABLE>
And you're costing yourself a lot of power because of some crazy internet mth, but whatever floats your boat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV »</TD></TR><TR><TD CLASS="quote">i've seen your car at etown many times before--when you told me bone stk ls/vtec
i was like--what a phucking d1ck, why is he lying
your car is very impressive
impressed me so much i started my ls/vtec turbo
at 6psi 13.30 at 105--still working out the bugs
I'm sure I'll see you at etown again this year
Haha! You have no idea know how many people didn't believe me, All I know is I wish I had pistons/rods....most of the money spent on my car goes towards cute JDM bullshit
That's pretty tight that you went LS/VTEC after seeing my car, get the bugs worked out and you will definetly get that 12 sec slip
I gotta replace my clutch, it started slipping after I got a new set of slicks. After that I'll be back at E-town. Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life »</TD></TR><TR><TD CLASS="quote">Chrome Pipes, what kind of horsepower and torque numbers are you running? I have an ls/vtec turbo with (soon to be) and 81.5mm bore and I too only have stock rods and no balancing or sleeves or anything. The only thing that will be different about anything below the HG will be the 81.5mm pistons. Last year I made 234whp and 190lbs of torque. I was interested in knowing what kind of mods you have and what numbers your producing. BTW im very impressed with those 1/4mile times. cool burnout in the vid too </TD></TR></TABLE>
Thanks man. If you are doing pistons, why not rods as well. If you are going to take everything apart, at the least get upgraded rod bolts.
The main reason why I didn't bust apart my LS block was that it only had like 1,000 miles on it. I have seen stock internal B-series engines put out over 400 whp and run 10's all day long. So when it came time to pit my motor together, I was willing to push the engine to its limit. The car was tuned at InlinePro. It put down 356 whp / 257 wtq at like 16-17 psi on C16
I know the a/f is a little hairy, but I have richened it up a bit since then
The engine setup is a basic as it gets:
Stock internal b16a head / stock internal b18a block
InlinePro 2mm headgasket
ARP headstuds
DRAG III kit - TO4E 60 trim / .63 a/r exhaust
2.5 in. dp -> 3.0 in. custom exhaust
Here's where it gets rediculous:
V-AFC, RC 440's, Walboro intank pump,
Cartech FMU
Sometimes I don't get why it works, but it does. Believe me. The car rides great - part throttle no problem. It's sometimes a little fussy in traffic, but rips it at WOT.
When I save up some $$$ I plan on getting AEM, until then I keep it at 12psi on the street and it has seen up to 20 psi on C16 at the track.....and once in a while on the Garden State Parkway
!I gotta replace my clutch, it started slipping after I got a new set of slicks. After that I'll be back at E-town. Good luck!
. The engine setup is a basic as it gets:
ARP headstuds
Cartech FMU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chrome Pipes »</TD></TR><TR><TD CLASS="quote">
ARP headstuds
Cartech FMU
I know this thread is kinda old, but how long has your car been running? Daily?
ARP headstuds
Cartech FMU
</TD></TR></TABLE>I know this thread is kinda old, but how long has your car been running? Daily?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster »</TD></TR><TR><TD CLASS="quote">
If you have the eagle rods already in there (hopefully the newer ones with the bigger rod bolts) I would think you would be good to 8k. </TD></TR></TABLE>
So, if I have the old eagle rods and shift at 85-8600k (while making 540hp)...I should be worried?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">
I am assuming you are talking to the other guy and not me. If me, then my car has been going since April 2004 (when I bought it, and have everything done at once). It's gone through about 27,000 miles at 15psi since April....nothing wrong, and now revving to 8000rpms.
</TD></TR></TABLE>I am assuming you are talking to the other guy and not me. If me, then my car has been going since April 2004 (when I bought it, and have everything done at once). It's gone through about 27,000 miles at 15psi since April....nothing wrong, and now revving to 8000rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">
I am assuming you are talking to the other guy and not me. If me, then my car has been going since April 2004 (when I bought it, and have everything done at once). It's gone through about 27,000 miles at 15psi since April....nothing wrong, and now revving to 8000rpms.</TD></TR></TABLE>
Daily driver right>? Whats your set up like
Yep daily driving, 9+ hour trips, several full boost runs everytime....setup is as follows: (copy and paste from my cardomain.com link in the sig...
Engine:
Drag Generation III Turbo Kit @ 14.5psi
Turbonetics T3/T4 .57
Thermal R&D 3" Stainless Steel
3" Downpipe
LS/VTEC
Brand New GSR Head - Port/Polished
Skunk 2 Valves & Springs
Skunk 2 Turbo Cams
Eagle Forged Rods
Wiseco 81.5mm 8.8:1 Pistons
Edelbrock Victor X Intake Manifold
Edelbrock 65mm Throttle Body
Exedy Stage 2 Thick Plate Metallic Clutch
Exedy Chrome-Moly Flywheel
Hondata S200B w/Datalogging & 3-Step
GM 3 Bar Map Sensor
RC Engineering 550cc Injectors
MSD Digital 6-Plus
MSD Blaster SS Coil
MSD CAP
MSD 8.5mm Wires
Denso Iridiums
AEM Fuel Pressure Regulator
Hondata Intake Gasket
DynoJet Wideband Commander O2 Sensor Kit
B&M Pro Edge Short Shifter
Oh yea, stock sleeves (yet) and no girdle (yet)....probably will do that next summer.
Modified by Dunc at 9:29 PM 4/30/2005
Engine:
3" Downpipe
LS/VTEC
Skunk 2 Turbo Cams
Eagle Forged Rods
GM 3 Bar Map Sensor
MSD Digital 6-Plus
MSD Blaster SS Coil
MSD CAP
MSD 8.5mm Wires
Denso Iridiums
turbosi03
May 6, 2004 02:49 PM
