Ls/vtec question,wiring harness etc.
Old Jul 14, 2011 | 12:27 PM
beastinisgr8's Avatar
Default Ls/vtec question,wiring harness etc.
I have an obd2 b18b1 and I bought a b16a head with wiring harness injectors and chipped ecu. My question is will anything be plug and play I know the harness wont work injectors are also different. So should I buy obd2 injectors and leave my harness? Thanks for all help
Old Jul 14, 2011 | 01:56 PM
Organization's Avatar
Default Re: Ls/vtec question,wiring harness etc.
does the b16a wiring harness complete from ecu to engine or is it just a jumper to convert obd2 to obd1
Old Jul 14, 2011 | 03:58 PM
Its just stock bay harness I bought motor but bottom end was junk. I read you can use ls dizzy but have to change the intake manifold? What manifold could I use
Old Jul 14, 2011 | 04:42 PM
look up bambam ls/vtec
i would use a dohc vtec dizzy and a b16 or type r intake manifold and if you have the whole engine harness to bay harness from a obd1 vtec car then use that cause it will make life that much easier or just get a obd2 to obd1 conversion harness and most if not all of the sensors should macth up you have to do some research depending on which way you go
toolbox21
Jun 12, 2012 09:50 AM
Seto-Initial-B
Dec 31, 2008 05:43 AM
whiteef8
Mar 30, 2008 10:53 AM
ph0shizzle
Dec 30, 2005 01:22 AM
u0f
Nov 18, 2003 10:36 PM
