ls/vtec question..
Old Feb 3, 2009 | 01:54 PM
418whpturboD's Avatar
Default ls/vtec question..
ok this is my setup..
stock block b18a1
built b16 head with rocket valvetrain
ctr cams
arp head studs
cometic .030 head gasket
str air maxx intake manifold
sls top mount ex. mani
garrett t3/ t61 .82 ar
3 in exhauust
presicion 1000s
any way the question is what sould i revv to.. having the ctr cams and the built head?? i no the bottem end is completly stock.. i was thinkin 8500 ish.. but i wanted other opinions..
Old Feb 3, 2009 | 02:10 PM
adam00's Avatar
Default Re: ls/vtec question..
i think you should get some arp rod bolts and i woundn't rev it past 7,500 just to be safe
Old Feb 3, 2009 | 02:13 PM
Silva Bullit DC4's Avatar
Your head may be built for high revs, but before even addressing that, I would consider building your bottom end before high revs, or at least replace the stock rod bolts with ARP's. The stock B18a rod bolts are not meant for high RPM.
Terrance.
Old Feb 4, 2009 | 09:36 PM
civickiller's Avatar
at least arp rod bolts and vtec oil pump
418whpturboD
Jun 25, 2009 11:40 AM
akura404
Mar 3, 2006 02:12 PM
mycrx7
15
Mar 10, 2005 08:33 PM
rough_draft
Jul 9, 2004 03:14 PM
ls95hatch
15
Apr 10, 2004 06:58 PM
