LS/VTEC Oil Galley
Old Aug 1, 2007 | 01:29 PM
Dunc's Avatar
BCICAN
Default LS/VTEC Oil Galley
The reason for putting this here is simply do to the huge amount of traffic and quick responses. If the mods feel this needs to be moved then feel free I guess.
Info:
I've read a little about how the oil galley needs to be "welded and machined flat for any vtec head because the ls block does not have this galley and it will keep oil from sitting on the headgasket which could lead to a potential leak."
Question:
- Does anyone have a picture of where/what exactly needs to be plugged? I have not a clue and don't know where to begin searching.
I assume mine is since I've been with this step up for about 3ish years. But the head is off the car getting a new valvetrain and figured that I would check to make sure.
Old Aug 1, 2007 | 02:39 PM
StolenTeg's Avatar
Default Re: LS/VTEC Oil Galley (Dunc)
http://images.google.com/imgre...a%3DN
Old Aug 1, 2007 | 02:42 PM
StolenTeg's Avatar
Default Re: LS/VTEC Oil Galley (StolenTeg)
All you need to do is tapped it and plug it with a plug and sealer
Old Aug 2, 2007 | 05:19 PM
Dunc's Avatar
BCICAN
Which hole is it though? Thank you for the help!
Old Aug 2, 2007 | 05:33 PM
paulzy's Avatar
https://honda-tech.com/zerothread/1676914
Old Aug 2, 2007 | 05:54 PM
Dunc's Avatar
BCICAN
Default Re: (paulzy)
Thanks! I assume it's plugged, but I'll check when it gets back from the machinist
Old Aug 2, 2007 | 08:18 PM
blackeg's Avatar
Default Re: (Dunc)
tap it 1/8th and plug it up
libral00
Mar 30, 2008 09:57 AM
0554
Jul 12, 2005 05:54 AM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
drumking15
May 14, 2003 10:06 AM
