LS/VTEC dyno very pleased!
My LS/VTEC built by Speed Innovations/RLZ ENGINEering and tuned by Howard at Speed innovations! Through filter and full exhaust!
317whp@10.2 psi
84mm LS/VTEC
RLZ head work w/ stock cams and cam gears
Edelbrock Inake mani.
Inline Pro SS mani.
Precision SC61 T3
Kteller exh.
Drag Intercooler need better one!
More RPM's and boost to come!
317whp@10.2 psi
84mm LS/VTEC
Inline Pro SS mani.
Precision SC61 T3
Kteller exh.
Re: LS/VTEC dyno very pleased! (SPOOLED)
Are you running stock sleeves? Pistons rods? What bottom end work have you done? Very impressive numbers. keep up the good work
Re: LS/VTEC dyno very pleased! (Targa4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life »</TD></TR><TR><TD CLASS="quote">Are you running stock sleeves? Pistons rods? What bottom end work have you done? Very impressive numbers. keep up the good work
AEBS sleeves, Wiseco pistons, Eagle Rods
Re: LS/VTEC dyno very pleased! (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi »</TD></TR><TR><TD CLASS="quote">numbers seems kinda low. I made 400whp on 10psi at 7500rpms with that turbo. I have a fully built 2.0L GSR </TD></TR></TABLE>
There is still a lot of power to be made if I was going all out but like the post says stock GSR cams and gears, but I don't see 400whp @10 psi with this set up and even compared to some others, but hey if you did it good for you
Congrats man those are good #s. Def has more potential by looking at the dyno graph, Your bro can spend more time on it
Edit:Oh yeah I saw your new paintjob IT IS SICK!!! I like it alot!!!
Re: (WREKONIZE V8 KLR)
Friend of mine made that much power on a bone stock B16 @ 11.5 psi with an SC61. Something's wrong if you have a sickly ported RLZ head, and an 84mm GSR to only make those numbers. How much timing was in it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLED »</TD></TR><TR><TD CLASS="quote">Crome!</TD></TR></TABLE>
Yea!!!....finnaly found someone else that uses Crome!!!
There is still a lot of power to be made if I was going all out but like the post says stock GSR cams and gears, but I don't see 400whp @10 psi with this set up and even compared to some others, but hey if you did it good for you </TD></TR></TABLE>
I was using stock GSR cams with aem cam gears Your setup is really nice. Good numbers like I said before
Guest
Posts: n/a
I thought the whole point of getting vtec was so that your bottom end didnt completely fall on its face? Your torque just drops off after 6000. Which is probably why you didnt make as much as you could have.
Modified by 95GSRTT at 2:20 AM 4/8/2005
Re: LS/VTEC dyno very pleased! (hotrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex »</TD></TR><TR><TD CLASS="quote">tq curve falls faster than a retard with one leg.... doesnt seem right</TD></TR></TABLE>
Haha, i like that one. The graph isn't working right now, so I can't really see what you guys are talking about. That ic is definitely not helping power output though!! I bet if you got a good head on there it would pick it up a bunch too! lol j/k brad
Re: LS/VTEC dyno very pleased! (tony1)
It has a decent Stock valve head on it.. It drives good thou..
There getting alot of Boost drop between the Turbo and Ic and Manifold..
I think the timming is pretty lax with the A/F ...
