LS/Vtec Calibration Issue-S300
Old Jan 29, 2008 | 01:04 PM
HybridEL's Avatar
Default LS/Vtec Calibration Issue-S300
This is more or less going to be my last shot at trying to get this running properly myself...
anyways
I'm running a Ls/vtec, and I have a S300 in a P28.
I tried uploading a stock P72(GSR) basemap, and the datalog is showing code 20 ( Electrical Load Detector ) and none of the gauges in the cluster are working.
Any ideas?
I have a datalog file for the 10 seconds or so the motor was running for before I shut it down.
Thanks guys
Old Jan 29, 2008 | 01:18 PM
sp00led's Avatar
Default Re: LS/Vtec Calibration Issue-S300 (HybridEL)
I have ELD disabled on my setup in s300. obdIIa chassis obdI gsr motor. Older cars have it in the hood fuse box. On newer models it's built in to the alternator. This is what i've read when i had issues a few setups ago with that. Someone correct me if I'm wrong.
Old Jan 29, 2008 | 01:31 PM
HybridEL's Avatar
Default Re: LS/Vtec Calibration Issue-S300 (sp00led)
Awesome, I remember seeing the ELD option under misc. when I disabled the knock sensor.
You're right, its an OBDII chassis with an OBDI Motor.
That will eliminate the code, but do you have any idea on why the cluster doesn't work?
Thanks buddy
Old Jan 29, 2008 | 05:03 PM
HybridEL's Avatar
Anyone?
Driving the car with no gauges doesn't sound like a good idea..
Old Jan 29, 2008 | 05:24 PM
93supercoupe's Avatar
its most likely the cluster, and not the managment/engine.
Old Jan 29, 2008 | 05:37 PM
HybridEL's Avatar
Default Re: LS/Vtec Calibration Issue-S300 (93supercoupe)
If I put in a stock single cam ecu, the cluster works fine
Old Jan 29, 2008 | 07:14 PM
mrbsponge's Avatar
whos jumper harness are you using? sounds like you may have a wire pinned wrong in the jumper somewhere, most likely your problem
Old Jan 30, 2008 | 12:46 AM
HybridEL's Avatar
Default Re: LS/Vtec Calibration Issue-S300 (mrbsponge)
Streetrays.
I'll try and find a different harness, and see if it works.
Pnoyej6
21
Jan 18, 2007 01:13 PM
the.hamburglar
Mar 16, 2006 05:55 AM
hondahans
153
Dec 5, 2005 08:24 PM
Ibanez
Sep 2, 2005 11:57 AM
DVS2000
Jul 2, 2001 11:15 PM
