LS/Vtec
Old May 30, 2005 | 05:50 PM
del_orson's Avatar
Default LS/Vtec
How well do LS/Vtec take boost with stock parts, and how much boost will they take? What is the comp ratio of the B18B with B16 head?
Old May 30, 2005 | 06:37 PM
Turbocivic94's Avatar
Default Re: LS/Vtec (del_orson)
They take boost very well, you can boost around 10 psi
Old May 30, 2005 | 08:37 PM
del_orson's Avatar
Default Re: LS/Vtec (Turbocivic94)
how high can I rev it? This is a stock B18B bottom end.
Old May 31, 2005 | 02:15 AM
BLWNB16A@11psi's Avatar
I am doing the same thing so input would be appreciatted.. But I am super charging at 10 psi
Old May 31, 2005 | 05:55 AM
I use to rev mine to 8500 rpm. You would be safe till around 8200. Your compression will be around 9:7:1. just get a good tune.
Old May 31, 2005 | 04:14 PM
del_orson's Avatar
so B18B are fairly strong on stock internals. Good
Old May 31, 2005 | 04:15 PM
del_orson's Avatar
what is max boost that you can run on stock LS/Vtecs?
Old Jun 1, 2005 | 01:16 AM
Outkast95LS's Avatar
bump for some answers
Old Jun 1, 2005 | 02:03 AM
93supercoupe's Avatar
Default Re: LS/Vtec (Nine5IntegraLS)
Im running 10lbs SC on a b18a w/ b16 pistons and GSR head.I goto 8200 in third
jdmitr757
Mid-Atlantic (Sales)
Apr 28, 2010 06:08 AM
eglslsd
Jun 9, 2007 08:20 PM
Green95LS
Apr 5, 2007 01:31 PM
10 psi
Aug 29, 2004 06:24 PM
B18PoweredCivic
May 3, 2003 10:00 AM
