LS/V-T piston ring gaps???
Old Mar 21, 2011 | 10:35 AM
TeggyBear_Ls's Avatar
Icon2 LS/V-T piston ring gaps???
Just wondering what are some general piston ring gaps that you guys have used/heard of for turbo, i'm building up my ls/vtec turbo to run 10-15psi (3-350whp), it's a daily driver, and going to hit the roadcourse Buttonwillow a few times as well.
i've got CP 9.0:1 pistons 81.5mm... the little card that came with the pistons says to set the 2nd ring slightly larger gap than the first.
according to it's cleacalculations, I want a minimum clearance of .017, but for turbo around .020?
i measured the clearance of the rings as they came to me
top ring: .015
2nd ring: .024
would I be fine just filing the top ring to around .020 and then leaving the 2nd ring how it is? Or just let me know some suggestions, thanks guys.
Old Mar 21, 2011 | 04:54 PM
Turbo-LS's Avatar
Default Re: LS/V-T piston ring gaps???
18 to 20 on top is good. Don't go any larger on the second ring I'm surprised there that size from cp.
Old Mar 21, 2011 | 11:45 PM
racebum's Avatar
that's actually good they came small. it's very easy to file fit larger, if they come too large....well.. you're just stuck 18 and 24 sounds good to me, 15 is an NA number
Dc4LsTeG
Engine Machining & Assembly
120
Sep 27, 2024 08:56 PM
extremeracer
Jun 3, 2009 06:08 AM
DrivinVtec
Oct 10, 2006 05:05 AM
sweet
Apr 23, 2003 05:06 PM
crxhybrid1320
Jan 6, 2003 07:02 PM
