LS Turbo ( LS engine question)
Old Jan 22, 2006 | 08:29 PM
Mushvroom's Avatar
Default LS Turbo ( LS engine question)
I am about to purchase a b18b motor with auto transmission into my ek which is 5 speed. I am going to use gsr or si tranny on my setup, what is needed to change the ls auto to manual, or is it pretty much dump the auto and install the b16 tranny and go? Thanx/
Old Jan 22, 2006 | 08:31 PM
Acrappyhatch's Avatar
why is this in FI?
Old Jan 22, 2006 | 08:42 PM
Mushvroom's Avatar
b/c i am doing a fi setup.
Old Jan 23, 2006 | 07:11 PM
Mushvroom's Avatar
just swap the tranny and get the b-series shift linkage?
Old Jan 23, 2006 | 09:19 PM
SiAutoX's Avatar
Default Re: (Mushvroom)
take off auto tranny and converter....install flywheel clutch tranny and shift linkage and your good
Old Jan 23, 2006 | 10:24 PM
Mushvroom's Avatar
thanx
Old Jan 24, 2006 | 01:46 PM
hbracer18's Avatar
there is a lot more than that. i did the same thing, yes you need clutch, flywheel, flywheel bolts, shift linkage, also need a starter the auto wont work and you will need a different rear motor mount too. it was a is a lot of work, it would have been cheaper if i would have bought a 5 speed but i bought new honda OEM stuff. just search. thats all i can remember its been a while since i swapped my motor out.
93civicsedan
Jun 10, 2004 07:26 AM
SpoonFedHatch
Feb 7, 2003 09:20 PM
meatball01
Dec 29, 2002 09:40 PM
ThatRicerDaniel
Oct 7, 2002 10:59 PM
acuraLSSE95
Aug 16, 2002 07:11 PM
