ls turbo help
Old Apr 15, 2014 | 03:38 PM
touchdown16's Avatar
Default ls turbo help
I have a stock ls integra 95, im doing a street turbo kit but looking for a little extra power. I need advice on what bolt ons are best. Such as intake manifold, tb, cam gears etc..thanks for the help
Old Apr 15, 2014 | 05:48 PM
TheShodan's Avatar
Moderator
Default Re: ls turbo help
Define "a little extra power".
Please read the FAQs at the top of the forum.
Check the B18B/A1 LS turbo forums for setups that look similar to what you're looking to achieve.
Old Apr 15, 2014 | 07:35 PM
wantboost's Avatar
Who is Mr Robot?
Have you even bothered reading and researching? near the bottom of the first page is this
https://honda-tech.com/forums/forced-induction-16/lst-ls-t-turbo-b18a-b18b-setups-1323059/
The ls turbo thread, read it and the FAQs, multiple times.
we don't spoon feed the new guy here as it doesn't help you at all.
Old Apr 15, 2014 | 10:13 PM
turbomaniac's Avatar
do your reserche at faqs
if little extra power is 50-100 hp, stock engine and stock CR is ok.
the only think you will need is new exhaust, a 30-40 lb/min turbo with oil lines, larger injectors, ecu remap, better clutch, intercooler kit (you can buy a bolt on from ebay), EGT or wide band O2 and a boost gauge.
Old Apr 16, 2014 | 10:16 AM
CaptainBuster's Avatar
Breathe ability is the key to a motors horsepower but not necessarily its survival. Just make sure whatever you put on your car your block/head can handle it. I won't go into detail about what part of the block/head can take what because it varies from motor age and wear. I will leave the educated guessing part to you if you decided to boost a motor on stock guts.
Old Apr 16, 2014 | 12:46 PM
Schister66's Avatar
Man U FTW
https://honda-tech.com/forums/showthread.php?t=1323059
This sums it up...
dumas07
Jul 17, 2006 10:01 AM
95_red_dc
May 29, 2006 04:32 PM
Teinman
Jul 7, 2004 05:58 PM
Silverhatch
May 10, 2003 08:59 AM
